Old 03-18-2009, 10:31 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
Simply amazing restoration Eckhard! That is one of the finest examples of ETV you have there. I'm glad there are others out there taking care of these beauties.
Beautiful set!
Jordan
Old 03-18-2009, 10:55 AM
What an astonishing set.
My hands would have been trembling while working on such a treasure!
It would be interesting to see a schematic diagram.
Old 03-18-2009, 12:14 PM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Hi Phil,
here are the actual schematics of the set including the changes, I have registered:
http://bs.cyty.com/menschen/e-etzold...Schematics.jpg
Note, that the AL5 spz. and the CY1 spez. are replaced by a 6DQ5 and a 6AF3, until I get the original tubes.
The set will leave my home in the next week :-(
Eckhard
Old 03-18-2009, 05:03 PM
ihmeyers ihmeyers is offline
Eckhard,
Beautiful, simply beautiful. What a rarity. Are there any more than maybe 1 or 2 other working examples?
I am in awe of what some of this board can do to bring these old beauties back to life.
Old 03-18-2009, 06:29 PM
John Folsom's Avatar
That is a fantastic set. Just curious, is in in a museum, or a private collection?
John Folsom
Old 03-19-2009, 02:47 AM
yagosaga's Avatar
VK Member
Hi,
There are IMHO ten surviving FE VIs today, you can find them photographed and listed on
http://fernsehen.bplaced.net/ind_tel.html
I know of another one of them, which is in working condition, you can see it even with a raster here:
http://www.drm-berlin.de/museum/2007/2007.html
The FE VI is the nmost commonly survived prewar set of all German prewar tv sets.
Kind regards,
Eckhard
Old 03-19-2009, 05:39 AM
I would be more nervous than a cat in a room full of rocking chairs tryin' to work on that bad boy...
Old 03-19-2009, 06:58 AM
yagosaga's Avatar
VK Member
This is the raster which appears on the screen without an antenna signal. I have got the same raster before I tuned in the channel.
Old 03-19-2009, 08:04 AM
tubesrule's Avatar
tubesrule tubesrule is offline
This is an interesting observation Eckhard. Looking at the schematic it appears that the line and frame oscillator stages use blocking oscillators, so I would have expected the set display a normal blank raster. What do you think is causing the displayed raster to look like this when no signal is present?
Old 03-19-2009, 01:29 PM
yagosaga's Avatar
VK Member
The height of the synchronisation input level can be controlled by the 5 K control at the cathode of the oscillator tube. My experience is, when I have adjusted the sync level for best synchronisation, and I draw the antenna plug, the raster looks frazzled.
Old 03-19-2009, 06:22 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Eckhard,
Really appreciate you sharing this unusal and rare receiver restoration. The set really reflects German prewar attention to detail in design and engineering. I am especially intrigued by the modern looking, metal framed, rectangular control panel (?) above the Telefunken name.
-Steve D.
Old 03-20-2009, 07:48 AM
yagosaga's Avatar
VK Member
Steve,
this control panel has only two switches. One switch is for sound (Ton), the other for vision (Bild). You can use this set as a radio, when switching on sound (Ton). When you switch on vision, the vision power supply, the valves of the vision I.F., video demodulator and the deflection units are heated, and the E.H.T. transformer is activated.
Kind regards,
Eckhard
Old 03-20-2009, 08:40 AM
electronjohn's Avatar
I like....big sparks!!
Fully-functioning 70 & 80 year old radios are commonplace on this site....but a working 72-year old television??? Congratulations on excellent work!
Old 03-20-2009, 08:53 AM
yagosaga's Avatar
VK Member
My next project will be a 81-year old television ;-)
Old 03-20-2009, 09:00 AM
Arkay's Avatar
Arkay Arkay is offline
Gorgeous and fascinating set, amazing restoration... On behalf of humankind, thanks for restoring that, and for sharing it!
Be yourself. Everyone else is taken.
