Old 05-31-2009, 06:20 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Originally Posted by radio nut View Post
I went to check the pots and I am confused now. The brightness pot per sams should be 5meg. Mine checks end to end 571k. If I put the ohmmeter from pin 1 to 2 and vary the conrtol it starts at 158ohms -goes to 2.486 meg and then back to 550k as I am turning it the same direction. I am used to pots breaking inside and just having no resistance. This I have yet to see. I take it that this pot is bad ?
Or, there could be 570K in parallel with 1 and 3 which would make it behave this way.
Old 06-03-2009, 10:55 AM
radio nut's Avatar
Born in the wrong decade
This is called learn as you go along. There is a parallel path that will throw of my test. I did not know that this could happen. Also I "assumed" that resistors that were fine a few months ago would not drift. I replaced one in the horiz circuit and now the picture is where it should be on the screen. Problem solved. Thanks everyone!
Old 06-03-2009, 11:08 AM
I always like happy endings, in more ways than one
Old 06-03-2009, 04:28 PM
Glad to hear it's going again !
