Old 11-25-2009, 09:11 AM
Robert Grant's Avatar
Originally Posted by John Folsom View Post
HI VKers.
<snip>
The Japanese channel assignments are a bit different. Here are the pairings we were able to make; US/Japan channel assignments 13/11, 2/12, 12/10, 11/9, 10/8,9/7, 8/6, 7/5. Channels 4,3,2, and 1 on the trinescope could be tuned to receive a signal from the cable, but these were cable channels which did not line up with the standard US 2-13 assignments.
<snip>
Japanese channels 1 through 4 were/are actually broadcast channels.
1, 2 and 3 are particulary notable for being 90-108 MHz (in the FM broadcast band in most of the world), which explains why Japanese FM is 76-90 MHz.
This was likely done because sporadic-E skip is especially frequent in Japan. The occurrence of sporadic-E drops off dramtically with increasing frequency, and analog television (AM video) is considered less robust under interference than FM radio.
Old 11-25-2009, 09:54 AM
tubesrule's Avatar
tubesrule tubesrule is offline
Cool set John. I hope you are able to bring it to next years convention.
BTW, your WC-01 has the Japanese RF channels programmed into it under "System M3" so you should be able to provide a signal for all channels on the set.
Darryl
Old 11-25-2009, 12:54 PM
John Folsom's Avatar
Robert, Thanks for the info on Japanese channels. I suspected some of the 1-4 channels were somewhere in the FM band. The local cable company uses these FM broadcast frequencies to squeeze in a few more channels.
Darryl, thanks! I had not even thought to try that. Should have realized the WC-01 can do ANYTHING!
John Folsom
