Old 12-28-2009, 06:29 PM
Cruiseomatic's Avatar
Cruiseomatic Cruiseomatic is offline
2 many toys,Not enough $$
Hey Steve,
Right now the Packard Bell is on a back burner for now since it does currently work. (Just a crackle in the back by the HV cage and sometimes diagonal lines on a black screen.) The Hoffman is my main thing right now. I don't know alot about old electronics so what I thought would be smarter is since it is a "Rare" find, (I'm not sure how rare it truely is. Would be nice to know.) I am going to have someone who is a pro in doing these kinds of things restore the chassis. Most I'm doing now is simply cleaning up 50+ years of dust grime and dirt. All purpose cleaner, Q-tips,paper towels and an old rag got the chassis to a real close polish. But them old circuits, Especially them old wax/paper caps are a B#$%# to clean to read them. I'm cleaning this one now since I have the chassis out and getting ready for the "Hospital". I know for a fact, The cleaner the object your working on, The easier it is. And since I know the guy and the amount of work I'm about to give him, I want everything to be easier for him. This poor set had to be in a smokers house, The speaker wires are grimy and sticky, Actually, almost all the wires are like that. Where is a place to get a new grille cloth and knobs for this set? Removing them old knobs,one broke off and the others are badly discolored and look brittle. I've decided that I'm going to have the Hoffman cabinet re-finished so she can relive her glory days. I hate seeing her like this. Cabinet beat to hell, Chassis inop, supposedly a bad tube, List goes on....But I have the determination to get all my old toys as close to new as possible. Still haven't been able to see a SAMS photofact to see how to remove the tube. It has a plastic housing that covers it that is busted in many places.
Old 12-28-2009, 07:29 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Chuck,
I doubt you'll be able to find those Hoffman knobs. They may have used the same type knobs on their B&W models. So that may help you out. Use great care removing all the knobs and trim pieces. Try some super glue to save the broken knob. Be patient. Don't pry anything that's stuck. Put the knobs in some mild dish soap w/warm water. Let them soak and use a fine toothbrush to clean them up. The grille cloth may have to be a close match. Check with Radio Daze www.radiodaze.com or Antique Electronic Supply www.tubesandmore.com/. There are other suppliers on the net. Looks like the plastic shroud that covers your 21AXP22 is in bad shape. Another junker color set, if you can find one, using the 21AX may have a good one. Or you can replace the tube with a later 21" tube. This will present some new problems in mounting the later glass tube in this set as the plastic shroud is part of the mounting hardware and probably won't work with the later glass tubes. Have your tech friend advise you on this. Color sets of this era are far more complex then B&W 50's sets. WAIT for the SAMS before removing the picture tube. Or anything else chassis wise. Lots of connections, cables ect to remove before you even loosen the chassis bolts. I know you want to get right on this. But don't hurry this project. Good luck in your restoration. I hope your tech friend has experience in repairing these vintage color sets. Not many of this model color receiver stll around. Finally, here's an article on these sets posted on the ETF site: ETF - 1957 Hoffman Colorcasters
Address:http://www.earlytelevision.org/hoffm...lorcaster.html Any other VKer's feel free to jump in on this.
-Steve D.
Old 12-28-2009, 09:53 PM
The Sams will go out in the mail Tuesday morning. Very, very close to the RCA CTC-5. I would have to have the schematics side-by-side to pick out differences.
As I mentioned elsewhere, it looks like the crt has already been changed to the newer type. (it has cataracts, which means they used a later bonded tube.) They may have damaged that cover in doing the conversion.
Can you take a close-up photo of the neck/socket on the crt? Would be interesting to know if it is really cracked. I need to go back and study your photos some more regardless.
Best of luck-this will be an adventure, but if I can get a CTC-5 working I guess anyone can!
Old 12-29-2009, 01:30 AM
Thanks bgadow. I'm hoping this restoration can go smoothly. I will get a picture tomorrow.
Old 12-29-2009, 05:27 AM
You'd BETTER-There's a whole bunch of us frothin' at the Mouth to see yr "new" playpretty...(grin)
Old 12-29-2009, 01:41 PM
Here are the pictures,Not the greatest, Had to sneak past the wife to get them.
Hope this helps.
BTW, Why is this Hoffman so "Rare and special"? I'm really curious. Is there like a registry as to how many are actually left or something?
Old 12-29-2009, 02:56 PM
bkharris's Avatar
bkharris bkharris is offline
Happened to look at some of my files and I have the original Hoffman Service Data file for chassis 706. In comparing it to the info contained in Sams 385-3, it looks to have a more detailed parts list and more detailed disassembly and alignment instructions. PM me if you are interested in getting a copy of these.
Old 12-29-2009, 03:16 PM
Got some status pictures up.
Here they are in order,
Little after work began (or before I started), Close up of old caps, Chassis as it sits on the bench now, and a completed circuit board.
Its not much, But given what it was last Saturday and what it is now, It's alot.
On the last one, I know there is still some gunk on it but I got what I could without actually removing the circuits. Q-tips can only go so far.
Old 12-29-2009, 03:46 PM
Homina ! Homina ! Homina !...(grin)
Old 12-29-2009, 03:55 PM
Lol, If someone could instruct me on how to remove the tube, I can begin cleaning the cabinet and trim pieces and show ya'll.
Old 12-29-2009, 09:26 PM
Ralph S Ralph S is offline
The pc boards you show look an awful lot like the boards in my CTC-5. I think Steve D's right when he mentioned Hoffman doing a ctc-5 clone.
Old 12-29-2009, 10:01 PM
Got the tube out. Its a 21FJP22A Made by RCA. Date code of Nov.6 1956.
I'm uploading some pictures of it now.
And my cabinet:
Old 12-29-2009, 10:18 PM
I would imagine the date code you see is stamped on the plastic crt cover? That is probably the date the cover (or maybe the set) was made. I say that because the 21FJP22A was not built until the 1960s. (edit: I couldn't see the photos when I wrote this)
The photos of the neck are good-and I don't see anything to indicate breakage. One pin looks a little bent-you just want to be careful with that one so it doesn't break. I think chances are very good that the crt is okay. If you can get ahold of pretty much any old crt tester that is still functioning, you could test it. An easy way to see if it is still under vacuum would be to connect the filament pins to 6v. A lantern battery would work fine for this. If they glow, it is at least a little alive.
The Hoffman is special because they were a relatively small company; they did not have strong national distribution. (I don't think I ever saw one around here) Plus, any color TV from the 50s is pretty rare. The only company that was cranking them out in any quantity back in '56/57 was RCA, and even they are scarce. Companies like Hoffman wanted to offer a color tv, maybe as a matter of pride as much as anything, but engineering one from scratch wasn't easy. Most outfits ended up either buying the makings of a color TV from RCA and putting them together themselves, or they licensed the design and built their own chassis.
You really did do well to find this set. You will not find many folks who have one. Fixed up nice and working, it will be worth a nice amount.
Old 12-29-2009, 10:27 PM
It might be when the set was made,but if so then it might...well...I don't know. It has the sticker but a different date code...Maybe the 2 tubes used the same mounting brackets but different types?
Old 12-30-2009, 12:57 PM
All those wax paper caps must be replaced. They are guaranteed to be bad and leaky today. But be careful of the old circuit boards, as the glue they used to hold the copper traces won't take a lot of soldering iron heat else they will peel off. What I often do is just clip the leads of the old cap right at the body of the old cap, leaving me with wire leads I can splice the new cap's leads onto. J hook method. Especially if getting to the other side of the board is difficult. Do one cap at a time, so you don't forget where what cap goes where.
