Old 01-22-2010, 05:14 PM
Locktals, midboys, whatever notwithstanding...I still think it's Purdy, & methinks I could find a place for it at the Casa De Sandy w/o undue trouble...
Old 01-22-2010, 05:29 PM
Yep, those are the original caps.
My 49-1280 used them too.
Old 01-22-2010, 05:33 PM
leadlike's Avatar
leadlike leadlike is offline
banderson, what happened to that vertical output transformer/choke looking thing in the upper right hand corner of the photo of your Philco? It looks so burned, or is that rust?
Old 01-22-2010, 05:52 PM
Originally Posted by John Marinello View Post
One like it in Minnesota sold last month
Sure enough. That one's missing the stretcher bar across the bottom. It's hard to see because of photo glare, but mine also has a slide-out panel covering the lower row of controls. A brass plate in the middle says Westinghouse. Apparently, the panel had two knobs or buttons with shafts that slid into holes in the cabinet body. If you look closely at the photo of the other cabinet, you can just see those two little holes.
Phil
Old 01-22-2010, 05:55 PM
Oops - I forgot to congratulate you on scoring an awesome set That's a really distinctive cabinet. I bet most folks would never think there's a TV hiding inside.
Just rust I think. This is the dirtiest set I've ever come across. Everything was covered in a a layer of dirt and pine needles, then fine black soot, then rust. Amazingly, I thing it's sound electrically. I'll fine out soon enough when I start restoring it in earnest.
Old 01-22-2010, 11:01 PM
Originally Posted by Phil Nelson View Post
To be honest, I've not had major problems with loktals, unless you count having trouble pulling one out from a very cramped space in a portable.
Dangdest thing, I don't recall ever having to replace a loctal tube. They seemed virtually bulletproof. Of course I never ran into a TV with loctals either, it was always just radios that had 'em. Bill(oc)
