Old 02-13-2010, 11:55 PM
Originally Posted by Charlie View Post
There's nothing like a little flash of light on the screen to mess up a night's sleep!! I've done that, too. About to call it a night, and then something positive happens unexpectedly... "Oh geez, can't go to bed now... I'll never get to sleep!"
That's awesome the way your speaker cloth came out! On the other hand, I think the peace sign was kinda cool!
Making progress... getting close! Won't be long now!
LOL - I was until 4am that night I kinda liked that piece sign too, but the stain had to go.
Although I haven't given up on this CRT, I couldn't resist picking up this Motorola chassis with a 16RP4A for $15
I hope it arrives in one piece!
File Type: jpg !Bl(g95Q!mk~$(KGrHqUH-CsEtr30UFklBLbbUiU1Sg~~_3.JPG (56.2 KB, 49 views)
Old 02-16-2010, 06:29 PM
Does anyone have a schematic specifically for a Sentinel 430 ?
I'm currently working from Sams set 124 Folder 9 which covers models 420, 423 and 424. That's the best they had to offer. It's close, real close, but I'm encountering subtle differences in the sync separator, dc restorer and horizontal circuits.
I also checked Beitmans 1951 which has 412-416, 420, 423, 424. Beitmans 1952 has 438-444
Old 02-21-2010, 07:44 PM
It's been a couple very, very frustrating weeks, but I think I'm in the home stretch. First, I liberated a replacement pot from my Airline set. Then, I discovered that not only did the sync/dc restorer circuit differ markedly from the schematic, but some parts were only connected at one end! Apparently, someone was tinkering with it way back when. I decided to rebuild it from the ground up according to the schematic.
Now I had a much brighter picture, but the horizontal sync went to hell
It appears I was wrong about this CRT - it still has some life in it
So, I started putting old parts back in (or new parts with the old values regardless of what the schematic called for) following the reference picture I had taken. Finally, when I got to the horizontal phase inverter, I got my sync back
Only problem now is the retrace lines are very prominent.
I remembered seeing an article at the ETF on a retrace mod and dug up this page. I was surprised to find that this mod was already in this set, but it wasn't doing the job. I experimented with the RC values and finally, got a bright, stable picture with no retrace lines
Time to fire up a test pattern and get that picture all squared away!
Old 02-21-2010, 08:06 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Hey that's awesome!!
Yeah, sometimes it seems there's simply no mercy, and then when you least expect it, it works!
Congrats!
Charlie Trahan
Old 02-21-2010, 09:38 PM
I have one of those B&K 440's it always show the crt as worse than my Sencore CR-70. And always the CRT seems better than what the 440 says.
Also the Sencore seems very good at the rejuv mode, have had good luck with it.
just something to think about.
Old 02-25-2010, 12:36 AM
My parts chassis with a 16KP4A arrived today. It was really, really well packed!
It turns out this a very nicely restored Motorola chassis. Does anyone recognize the handy-work ?
I wonder what happended to the cabinet
Here's the GE 16KP4A.
Unfortunately, it reads absolutely 0 on both my CRT testers
Maybe it's just a loose cathode connection inside the base cap ?
I suppose worse case scenario I have a really nice parts chassis for my Motorola 12K2 and a tube for Hawkeye to rebuild.
Old 02-25-2010, 07:16 AM
miniman82's Avatar
First Light: 1952-2011
Thread jack: That's a pretty simple mod, I'd like to use it on my Philco which shows retrace lines at high intensity. Problem is on the Philco, the pic tube cathode is used for brightness and the grid is driven by the video amp tube. How could I change this simple circuit to work with the grid vice the cathode, if that's even possibe? I assume I'd need a phase inverter, and a coupling cap at the very least.
Old 02-25-2010, 08:12 AM
Charlie's Avatar
On Land
Looks like someone's done all the hard work for ya on that one! Yes, one of the pins in your socket could need resoldering. I had a NOS 21EP4 that gave a dead element on one of the pins and feeding more solder in the pin fixed that... then tested like new.
Charlie Trahan
Old 02-25-2010, 08:28 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
And if resoldering the pins doesn't help you can always try the re-weld the cathode trick as a last resort.
Old 02-25-2010, 02:40 PM
I'm glad you asked - I had the same problem with this set!
What I did was feed the vertical pulse into the cathode along with the brightness control and leave the video grid alone. It wasn't working at first because the 0.05 cap on the cathode was filtering it out. So i cut that down to 0.02 and reduced the resistor to 3.9K.
I hope this helps.
Old 02-25-2010, 05:13 PM
I took the base off - it was loose already. It's not a bad solder joint
Here's the best photo I could manage. To my eyes it looks like the cathode connection is OK, but I can't see all of it. What's the cathode re-weld trick ?
Old 02-25-2010, 10:05 PM
miniman82's Avatar
Every once in a while I get lucky!
Thanks, I'll have to give it a shot.
Old 02-25-2010, 11:28 PM
that chassis looks a LOT like the motorola TS-14 I am working on.
Old 02-25-2010, 11:49 PM
It's a TS-60. I have a TS-23 that looks the same too. They made a bunch of chassis that were all very similar.
Old 02-26-2010, 01:13 AM
jeyurkon's Avatar
This is from the Sencore CR31A SuperMack manual, so I don't know if it works with all rejuvenators.
If a CRT indicates absolutely no emission, and the filament is still working, an open cathode is indicated. When this occurs the automatic controlled REMOVE G1 SHORTS circuite of the CR31 can be used in an attempt to weld the cathode. (goes on to talk about resoldering the pins first).
1. Set the BEAM BUILDER function switch to the REJUV 2 position and allow the filament to warm up for 60 seconds.
2. Set the Function switch to the REMOVE G1 SHORTS position and IMMEDIATELY press the REJUVENATE OR RESTORE button before the filament has time to cool. At the same time, tap the neck of the CRT.
3. If a flash occurs in the CRT neck, release the REJUVENTATE OR RESTORE button. Return to the CRT TEST section and check the CRT for emission. If no flash occurs and/or no emission can be read on the meter, the cathode cannot be welded to restore performance.
