Thanks to tvdude1, I have a complete set of knobs
As for the CRT, it's on the way to Scotty for a rebuild ![]()
I just got my rebuilt CRT back from Hawkeye. I'm glad I had this old CRT box handy. It made shipping a breeze. I just put inside a slightly larger box with foam between.
![]() That's real pretty. I wasn't expecting Scotty to recoat the DAG and put a label on it. ![]() ![]() I haven't restored this chassis yet, so I'll have to pull out another chassis to give it a try. This rebuild cost several times what I paid for the whole set, but I wanted to do it anyway. One, this is a 1st gen. 10FP4 from 1947 and I think it's cool to bring it back to life. Two, it's the only CRT I've ever had rebuilt. Hopefully, it won't be the last, but I fear it might. Last edited by bandersen; 08-04-2010 at 12:28 PM. |
That cartridge nearly never goes bad, but, you might have a major problem replacing the needle. I used to have a rough 802. A hack job. Someone tried converting original to 14" rectangular. Fried chassis. Cabinet was hacked. I picked up a rough original chassis, and, what was left of case. It had been sawed in half. I took the entire front panel, and, with difficulty, installed it on hacked case. I rebuilt chassis, but, major problems. Radio, and, phono would play great. Reception was fantastic! But, when I switched it to television, loud POP, smoke, and, B+ crashed! Apparently, the selector switch had gone bad, and, was dead shorted. I wasn't able to fix it, and, traded it off. I was told those switches in the 802 had a big problem with shorting. At the time, they offered factory replacements. Multi section switch. The fm reception on radio was really fantastic, and, sound was excellent! Bill Cahill Oh, well, I still have the original re built three prong cheater cord. Maybe someday I'll get another 802.
"Tubes are those little glass things that light up orange unless there is a short.. Then they light up all pretty colors..." Please join my forum. http://www.tuberadioforum.com/ |
Thanks for the phonograph info. I need to pick up some 78s to try it out.
Yikes! That selector switch sure does need to handle a lot of current. I think it turns on/off all the filament juice to the TV tubes depending on the mode. I'll be sure to check mine and replace it somehow if it looks fried. Last edited by bandersen; 08-04-2010 at 01:02 PM. |
I slapped the rebuilt 10FP4 into an Admiral chassis to try it out. It's really bright
Even with the brightness turned down all the way, the picture is quite watchable.Here's a sample. Note that I didn't make all the adjustments like centering. I just wanted to make sure it was working.
| Audiokarma |
