Old 08-29-2010, 01:27 AM
Here's a closer look at those cans. Very nice
Other repairs aren't quite so nice. I better double check the correct values on those caps that are doubled up.
I wonder where that ground lead used to go
Plenty of multi-colored heatshrink tubing all around.
Overall it looks pretty good. I'll need to dig up a field coil speaker to try it out. Or maybe a PM one and use a power resistor in place of the FC.
Old 08-29-2010, 03:25 AM
leadlike's Avatar
leadlike leadlike is offline
Those can condensers are very expensive. I would have thought he would have done a better job on the rest of the chassis, though. My guess-guy restored radios, and this was his first tv. I know the first tv I worked on was slopped together pretty bad, too.
Old 08-29-2010, 09:29 AM
I always wondered why Motorola painted the one side where the power supply components were. Possibly to run cooler? They only did it on the earlier models. Dave.
Old 09-07-2010, 03:54 PM
Good question. Cooling, insulation, "keep away" warning ?
I picked up a set of NOS knobs from peverett. Even they suffer from the white crud syndrome.
That cleaned off easily with a little 409. I then spent a lot of time polishing up the outer knobs.
They looked so bad at first I was convinced they were just plated steel.
Finally after a lot of buffing with Simichrome, the brass started to shine
Old 09-07-2010, 04:03 PM
nice cans, do the ones with out the cardboard tubes have voltage on them? I assume with the wafer it had a float ground or they were hot compare to the chassis.
Old 09-07-2010, 04:19 PM
They are at a floating ground potential. This TS-60 chassis is a hybrid design. The B+ supply uses an AC line voltage doubler (the cardboard tube cap and seleniums).
However, there is a 6.3 VAC transformer for the filament supply. So no worries about current surge or uneven heating of cold filaments
Old 09-22-2010, 10:30 PM
Tubejunke's Avatar
Yes, he is lucky to have landed that set with golden caps in it. I notice that you addressed a floating ground signified by the "wafer" or insulating base at the bottom of the cans. I bet a LOT of troubles have crossed these forums posted by people who assume that all electrolytic negative sides (outer metal can) go to the chassis for grounding. I almost made this mistake once before a lot of formal training. Honestly, I have not studied the circuitry enough to know why some manufactures did this or what would be the result of a mis-connection. Do you know much about this Dave?
Old 01-18-2011, 11:57 AM
Here's a nice intact version of this set on ebay: http://cgi.ebay.com/Vintage-Motorola...-/220726860074
Now I know what it should look like including the back I wouldn't take a chance shipping it, but maybe someone can do a local pickup ?
Old 06-04-2011, 12:57 AM
With my Motorola 12K2 project and it's oh so similar TS-53 chassis fresh on my mind, I decided to try firing it up.
I removed the 16KP4 and put it out of harms way.
I first tried powering it up with no speaker field coil so no B+ for the set. The tube filaments lit up just fine
I'm missing the original FC speaker for this set so I'm going to use a power resistor. I measured the FC resistance in my 12K2 speaker and got 90 ohms.
I went with a 120 ohm power resistor for a little safety margin. I also used an 8 ohm PM speaker.
That got me a nice raster, but so sound or video. All the tubes were pulled from a working set set I'm pretty sure they're OK.
I noticed that the previous owner hadn't replaced a single resistor and a few old caps remain so I'll start checking & replacing those.
Here it is with an 8XP4. At least the HV is nice and strong.
Old 06-04-2011, 08:31 PM
I fed a video signal directly into the grid of the final video amp stage. No image if I feed a signal into the IF stages. I think the fault lies somewhere around the detector.
Old 06-05-2011, 01:58 PM
Detector early SS detector diodes(if that is what your set uses) can and do go bad occaisionally. I'd try a replacement.
Old 06-05-2011, 03:26 PM
It uses one half of a 6AL5 with the other half unused. Unfortunately, I was doing a little tube swapping and lost the test pattern altogether. I hope it's just a bad connection somewhere.
Old 06-06-2011, 03:00 PM
It took me a couple days to figure out that this choke was open
It connects the IF strip to ground. Without it in the circuit, the cathode voltages were all way off.
I also noticed that the 6AG5 tube wasn't lit up anymore and discovered another bad choke in the filament supply.
I bypassed all of them with some clip leads.
Finally, some video The sound is good too.
I'm not sure if I have any suitable chokes on hand. I wonder how critical the value is
Old 06-06-2011, 04:36 PM
The original reason I picked up this chassis was to use this 16KP4 in my Sentinel. So I'd like to adapt the chassis to hold a 17BP4 like this.
I think it will fit a little better in the screen bezel and I have a couple spares.
Perhaps I can bend the old bracket or make a new one from scratch.
Old 06-07-2011, 01:15 AM
Not at all critical. Similar to a decoupling bypass cap. Anything vaguely resembling the value will work.
