Old 09-10-2010, 02:32 PM
No question that the earlier 53LC2 clock radio has much more eye appeal then the plain 54L1 that I posted above... This site says that even the clock radio is often overlooked :
http://www.radiolaguy.com/Showcase/MotorolaPortaClk.htm
Note that the "inverted" speaker on this earlier set is a different design than the one used in the Westinghouse transistor portable and the 54L1, looks like the later design might have been cheaper to produce.
Old 09-12-2010, 05:17 PM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
coupla more photos FYI and FWIW...
all the best,
mrh
Old 09-13-2010, 02:43 PM
Bill Cahill's Avatar
Super Moderator
Post
Well, radio arrived safely in the mail today.
Case is pretty rough, as stated.
I pulled mine down, which I haven't had open in years.
You'll never believe this!
Mine has an original 9 volt battery plugged in, dead as a door nail!
It had leaked, and, other battery clips are ruinned, as are their mounting studs in case.
The diagram shows it uses 6 D cell batteries, sayd nothing about a 9 volt battery.
And, that battery, I've never seen anything like it in my life!
It's about 6" long, is Eveready, and, has a long number on it. I doubt it could still be purchased.
It snaps into those other battery clips.
Is the radio supposed to take the 6 batteries, and, the 9 volt, or, what??
All battery clips are connected with wires, and, that 9 volt battery is connectedwith that 2 prong plug.
Is this a 9 volt radio, or, higher than that?
I know back in the early days the first transistor radios work on something like a 90 volt battery.
Is this an 18 volt radio,or, what??
Anybody got a schematic on this set?
Looks like an interesting radio to me....
Bill Cahill
Please join my forum.
Old 09-13-2010, 03:20 PM
Bill Cahill
It looks like the radio is set up to use 6 "D" cells or an enclosed battery, such as the Eveready 2762N or 2761N or perhaps 2506... Notice the outlet plug in the lid next to the speaker that matches the battery connector. My guess is that if 6 "D" cells are used, the 2 prong plug from the radio would be plugged in there. If a large 9 volt battery is used, then of course the 2 prong plug from the radio would be plugged into the battery directly.
Clever Design!
Old 09-13-2010, 03:27 PM
Super Moderator
Cool
Hmmm. Didn't see socket. Thanks.
Is that 9 volt battery even obtainable anymore? I doubt it.
It's quite large.
Very interesting radio.
Bill Cahill
Old 09-13-2010, 03:35 PM
In one of the pictures from this thread:
It is the brown socket just to the left of the speaker...It appears to be wired to the battery clips on the other half of the radio.
PS: Found a nice youtube video (by batterymaker) of one loaded with "D" cells and battery connector plugged into outlet left of loudspeaker...caption on video says that a 2761 battery can also be used:
http://www.youtube.com/watch?v=K--c6jKU4qo
Old 09-14-2010, 07:08 PM
akent36 akent36 is offline
Originally Posted by batterymaker View Post
That Motorola is usually looked over because they also brought out a same-chassis portable that had a wind-up clock in it--and that's the one collectors really go after.
Yeah, mine has the clock--cost $2 at a radio meet earlier this year.
Old 09-15-2010, 10:14 AM
mhardy6647's Avatar
Bill Cahill
Glad it got there in as close to one piece as it was when it left here! :-)
No idea about the batteries; it was my first encounter with this model. Sounds like you've gotten plenty of good advice and info. Wonder if the radio is in Sams' "TRS" series (I didn't check).
Hope you can synthesize a working radio out of the two that you now have!
EDIT: If you wouldn't mind, please post a picture of the one you already had sometime.
all the best,
mrh
Old 09-15-2010, 11:54 AM
I have this same radio in yellow and white and it is a 9V radio. It has the option of either using 6 "D" cell batteries or that oddball 9V battery pack. To use "D" cells, plug the cable for the oddball battery pack into a socket on the radio. To use the single 9V pack, remove the "D" cells, unplug the battery cable, and plug it into the 9V battery pack.
Old 09-15-2010, 03:51 PM
Bill Cahill
I think this should serve as a "heads up" to those of us that collect battery portables. Today, after reading that post, I started a "back off" inspection of the radios in my transistor set collection, and have already found 2 with batteries left inside.
Only one had leaked slightly, and no real damage was done.
Tomorrow, I will go through the tube portables...who knows what I will discover there.
I like to keep batteries in a few good players for demo purposes, I guess that it would be a good idea to clearly mark these sets, so that they get a regular turn on or inspection.
Update: Finished the "display" transistor set audit...found 3 more radios loaded with batteries that should not have been... all leaking, but a fairly easy clean up. I had to re-attach a wire to one contact (the wire had been eaten away) and it was was very difficult to tin the wire and solder it. Put fresh batteries in one radio for demo purposes.
Old 09-15-2010, 07:42 PM
batterymaker's Avatar
Repro Battery Builder
Any chance you could take a couple pix of that battery? I started making a repro, but had to stop to attend to other projects.
Old 09-15-2010, 10:01 PM
Super Moderator
Post
My camera isn't great, but, I will see what I can do.
I'll try tommorrow.
Bill Cahill
Old 09-15-2010, 10:57 PM
Your avatar reminds me of the question I sometimes ask: "Why do battery makers insist on putting corrosive crap in batteries?"
Old 09-16-2010, 07:58 AM
electroking's Avatar
a- v- karma member
Wink
It's like the smoke in transistors: annoying when it comes out,
but if it weren't there the device would not work.
Old 11-23-2010, 08:19 PM
wingzam wingzam is offline
Lifes hard,fail BIG
All too often I find old radios with leaking batteries.I've got an old Panasonic that is in nearly mint condition and I was so excited...until I removed the battery cover...does anyone know how to clean up the mess?I mean is there a neutralizing spray you can shoot on the area and contacts?Battery leakage on motorcycles and cars I use baking soda and water but what a mess that can be to clean up in a radio!
