Old 01-13-2011, 09:07 PM
All the cans are re stuffed and about half or slightly more of the paper caps have been replaced.
There are still three small axial Lytics under the chassis to be replaced.
Perhaps later this evening I'll be ready for a test run.
I found the green corroded leads of a 150 ohm 3w resistor that had completely fallen off, I don't know where the rest of it went, I never saw it when I removed the chassis. It went to one of the Filters so it's probably important, could explain why it was totally non functional.
Old 01-14-2011, 04:47 AM
I finished the recapping tonight and have been working on the set for the last 4 hours.
I complicated matters somewhat by leaving a capacitor unconnected at one end and forgetting to solder the ground wire on one of the stuffed cans but I did finally get a picture on it, not a very good one either.
The HV rectifiers must be weak, the HV drops like a stone when the brightness is turned up, either that or the .001@10k ceramic caps aren't a very good sub for the .0005@10k Sprague paper caps, I would think they should be fine since they are double the value and are just for the doubler circuit.
I went ahead and bought a couple NOS Sylvania 5642's to put in it, they were only $4 each.
The Flyback setup on this set is more than a little bit of a pain in the butt to work on, you have to unbolt the yoke to remove the cage since it's all one piece.
The other problem I noticed is the Phasing is off, I have a picture split right down the middle with the left half on the right side and the right side on the left, oh well, one step at a time.
Old 01-14-2011, 09:55 AM
heathkit tv's Avatar
heathkit tv heathkit tv is offline
VK Member
All these difficulties makes me wonder how they were able to align/set up TVs at the factory. Imagine their having to do this accurately AND quickly. Yikes
Old 01-14-2011, 04:15 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
I meant to take the Wallace's in to work to scan today but forgot.
I'll look at the schematic when I get home tonight. I think the circuit is similar to my Sylvania and I think it was the tube acting as a variable reactance that had a very small grid leak causing the same problem that you're observing.
Actually in mine there were two causes. I also had an open video IF transformer, but enough signal was leaking through it to give me a distorted picture that looked like only a horizontal problem.
Old 01-14-2011, 05:09 PM
Thanks John, the 6BF5 Video output tube is somewhat weak but I just checked it again and it's not all that bad, no shorts either.
I'm getting strong video but there is some horizontal ghosting that moves across the screen when I adjust the Horiz Hold coil, it never quite disappears before the picture loses sync, in either direction.
Otherwise I have a good stable picture, no rolling, no jitters, good sound, just split in two, it's dim though, I attribute that to the low HV which is about 10k with no load but drops as the brightness is brought up, I can see the picture well enough to see whats going on.
I'm poking around checking resistors and voltages today, so far everything looks really good.
I had the same problem on a Sonora I rebuilt, in that case it was the replacement Flyback had the polarity reversed on a winding that affected the pulse that affected the Phasing, I can't remember exactly how it worked but I had to reverse the connections to the winding to fix it.
Someone has replaced or tinkered with the Horiz Size Coil at some time, I could tell because of the spliced wires inside the HV cage.
I don't see how that would really affect it but I mention it just in case.
The .0005 cap C213 seems to be hooked to the wrong side of C211 according to the schematic,, it looked like that was factory wiring however, I tried it on both sides and it doesn't seem to matter much so I put it back like it was.
I'm having some difficulty understanding how the Phasing and Sync are related, i.e. what section should I be looking in to find the problem.
If anyone has any suggestions please chime in, here's a link to the schematic picture kindly provided by John.
http://vintagetvsets.com/schem/sylschem.jpg
I'll have to replace or cover the Yoke wires when I finally do get it working, they are so dry and brittle they kinked and cracked from all the moving around while removing the HV cover numerous times, it looks terrible, couldn't be avoided, just one of those things that happen on 60 year old sets.
Old 01-14-2011, 06:21 PM
Video posted
I posted a short video showing what's happening with this set. http://www.youtube.com/watch?v=C9HuJxELL6c
In other news, this set uses one of those integrated circuit type Vertical Integrator things, looks like a large flat Ceramic Disc cap, anyhow the center leg of it is broken completely off the component, I would expect this to only affect the Vertical section since the Sync for the Horiz is taken off immediately before this section.
I can poke the leg back into the hole and it makes a very slight difference in the Vertical but has no apparent affect at all on the Horizontal.
I suppose I'll have to build one of these out of individual parts, it seems to be a very typical Vertical circuit with the 8200 ohm resistors and some small value caps.
It makes so little difference Mad Man Muntz would just cut it out and leave it that way.
Old 01-14-2011, 06:37 PM
maybe some noise on the sync pulse out of the sync sep. Try scoping it and see if you get a nice clean series of sync pulses at 15kc.
Old 01-14-2011, 09:06 PM
jeyurkon's Avatar
I've attached the instructions for adjusting the phase and... It's from a different model, but the procedure is the same.
If V17 the 6AU6 has any grid leakage at all you won't be able to make the adjustment work. Most tube testers won't have enough sensitivity for this test and you need to use a leakage tester.
This set doesn't use feedback from the flyback to control the phasing.
Uhh, I just realized the numbers are different. Where it says R90 it should be R226, the ringing coil is L63. B1 should be sticking out the back of the set and B3 should be in the same transformer, but on this inside.
Last edited by jeyurkon; 01-14-2011 at 09:14 PM. Reason: Translation of identifiers
Old 01-14-2011, 10:27 PM
miniman82's Avatar
First Light: 1952-2011
Looks like the horizontal oscilator never really locks onto anything, it's just drifting through it's range. Looks exactly like my CTC-7 when I couldn't get the chroma demods to work correctly, the colors would just float by and never settle into a stable picture like it should. I suggest you begin looking at your sync seperator section and if that's working as advetised, see if the sync signal is actually making it to the horizontal section.
Evolution...
Old 01-14-2011, 11:06 PM
You just can't trust a Tube Tester.
Good grief John, you nailed it on the first try.
I swapped out V17 with one of the Sound i.f. tubes and the set started working!
I retested that rube and it checks very good, however bumping up the heater a little made the Short light start to flicker a little, after that it stayed on dimly, testing it the first time it just didn't get hot enough to show up the problem.
The second tube was a even little jittery when tapped so I tried another, now it's really solid.
Those same tubes work fine in the Audio section but I'll replace them anyway.
It's been messed with so much I still need to run through that setup procedure but at least it's working, when I get the new HV rectifiers in I'll try it with the 17" tube.
Old 01-14-2011, 11:08 PM
I should have mentioned in my video that i was turning the Oscillator coil back and forth, it would lock, just not where it should.
Old 01-14-2011, 11:19 PM
Sweet Glad you got it working.
I've been finding more and more that tube testers don't tell the whole story. That includes tubes that test weak but work just fine!
Old 01-15-2011, 06:56 AM
Well it's 4:45am and I couldn't sleep so I thought I'd post a little more on the progress.
Another tube that tube testers really can't tell you much about is the 5U4, both of the ones in this set checked good but weren't really.
They are wired in Parallel in this set so you can pull one out and the set keeps on working, I pulled the first one out and it kept working fine, a little picture shrinkage and the sound dropped a bit but nothing dramatic.
I put the first 5U4 back in and pulled the second, well, a huge difference, the picture shrank and dimmed almost to the point of disappearing!
I scrounged up another tube from another set and tried it, now the picture was stable on either 5U4 but a little better on the replacement tube so I scrounged another one, now it worked well on either tube by itself.
This also increased the High Voltage substantially, it's running 12k with the picture adjusted to normal brightness, it still drops if I crank the brightness way up but I believe it has enough oomph to try the 17" tube in it.
The Horizontal is working pretty well but it still drifts after a while so that it gets a ghosting or fold over creeping in from the left side of the screen after a while, I can adjust it out but it comes back. I still need to run the setup but there may be a resistor drifting a little after it gets hot, I'll poke around more tomorrow and see what I can find, I'll try the big CRT also, I'd like to see how it looks even though it checks good.
Old 01-15-2011, 08:36 AM
...The Horizontal is working pretty well but it still drifts after a while so that it gets a ghosting or fold over creeping in from the left side of the screen after a while, I can adjust it out but it comes back.
Have you verified that the 6AL5 phase detector (discriminator) is good and that it's lighting up? That would be the first thing to verify based on the symptoms you describe. Bill(oc)
Old 01-15-2011, 01:36 PM
jeyurkon's Avatar
The 4.3 ohm resistor in series with the heater for that tube might have shifted value also. But it might be more stable once you go through the setup.
