Old 02-24-2011, 10:08 AM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
This is starting to sound like a Slip Plate promo (I do not have stock in this company).
It's an industrial metal-to-metal lubricant, and it sets quite hard. I expect it to be more than adequate for my use. I originally bought it as a CRT coating (based on someone else's experience) when I couldn't find the usual materials (Aquadag etc.)
https://picasaweb.google.com/lh/phot...eat=directlink
In the short term it works well. After hooking up the rebuilt condenser block on the bench, the volume control worked properly.
-Winky
Old 02-06-2014, 12:08 AM
Winky Dink's Avatar
Unhappy This Did Not Work
A quick update on this. I wouldn't want someone in the future to follow the previous advice in this thread and run into the long-term failure that I had.
Over a period of months, the rheostat resistance continued to decrease. After a year it was hopeless--full volume at the lowest setting. Either the Slip-Plate continued to lose volatile components or the graphite was burnished and condensed where the sweep contacted the surface.
I decided to try plain graphite mixed with epoxy cement. I used the tiniest amount of epoxy that allow me to make a paste with graphite and applied it to a fresh piece of card stock cut in the proper shape to fit the rheostat. After many trials I found a mix that would give me a smooth increase in volume--but in only one third of the rheostat's normal rotation to reach max volume. That was good enough for me.
It's been almost two years since I did that, and it's still stable. The radio is only used about once a week, so in the very long term the rheostat could still fail. I'll let you know how it works five years from now, so stay healthy.
Winky Dink
Damn the patina,
Full speed ahead!
