Old 04-08-2011, 08:50 AM
miniman82's Avatar
First Light: 1952-2011
I've tried several things: acetone, methyl alcohol, grain alcohol, stripper, spirits....
Nothing touches it, nothing. I always resort to chipping the lens off with a screwdriver, since I use tubes in sets with flat glass anyway.
Evolution...
Old 04-08-2011, 09:29 AM
VintagePC's Avatar
Tube bug got me 05/2010
In light of that I'd suspect there are numerous additives they put in it to get it to bond to the glass; those additives must be what solublizes in the water and also keeps things from easily eating away at the PVA.
Old 04-08-2011, 02:42 PM
I can def see the little stress fingers around the edges where the toothpics are. Just have to be careful handling it with all the water making for slippery handling...
Old 04-08-2011, 02:57 PM
I wonder if there are any chemists on VK or ARF that would be willing to research the possibility of designing a coumpound to disolve PVA in a comparable amount of time to the risky heat method?
Old 04-08-2011, 04:40 PM
miniman82's Avatar
Trouble is anything that's going to work well is also going to be very nasty, and leaving something like that open is a no-no.
Evolution...
Old 04-08-2011, 05:18 PM
VintagePC's Avatar
Agreed. I'd further suspect that trying to dissolve the PVA will leave you with a nice gummy mess on your tube and safety glass... If we can find out the bonding agent that is affected by the water, it may be possible to do better. I wonder if it would make a difference to gently heat the water to say, 40/50 degrees C. Not too stressful for the tube, and if done slowly, it allows a thermal gradient to establish with minimal stress.
Old 04-08-2011, 11:31 PM
Zenith comes close with their patent for reducing thermal gradients during CRT "salvage"
How about Acetic acid for a solvent? PVA glue (Titebond wood glue) reacts to the stuff....someone with salvaged PVA could possibly test the theory.
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 04-09-2011, 12:04 AM
ctc17 ctc17 is offline
Seems like if you used a solvent it would result in a gooey toxic mess to clean up. Thats how the Zenith green halo ones are, its like jello that smells like a combination of sewage and used crankcase oil.
I avoid the Zenith ones now because cleanup is so time consuming. Yea you can cut the window off in 20 seconds with a piano wire, but then spend a week trying to get that goo off.
I have a piece of pva, ill try some solvents when I get time but still think I would prefer water.
Old 04-09-2011, 11:16 AM
miniman82's Avatar
So, stick the tube in a vat of vinegar?
Evolution...
Old 04-09-2011, 11:26 AM
VintagePC's Avatar
If it was pure PVA, then vinegar might work... see here:
http://www.ehow.com/how_5650421_dissolve-wood-glue.html
Worth a shot, I guess.
Edit: Glacial acetic acid would be more potent... but harder to get a hold of. You could probably make some by distilling or concentrating vinegar, depending on the acetic acid boiling point.
Old 04-09-2011, 12:21 PM
dumped in 1/2 gal of vinegar...
Old 04-09-2011, 12:37 PM
leadlike's Avatar
leadlike leadlike is offline
DO NOT dump glacial acetic acid into a pool like that (if you happen across some). If the smell doesn't blow you away (it can damage the lungs) it will likely dissolve the pool. A half gallon of vinegar probably won't do much of anything, but hey, it can't hurt, and it's cheap enough.
I remember seeing a posting with pictures of this kiddie pool submersion method, and they stuck popsicle sticks into the edges of the pva as it worked loose. It did a great deal to speed up the process.
Old 04-09-2011, 12:51 PM
I can see that I will have to keep an eye on it for evaporation losses.
You can make a little tent with a blue tarp or taped-together garbage bags. Could help with smells, too.
Old 04-09-2011, 02:44 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
I recently learned, to my surprise, that glacial acetic acid is flammable.
The article on reducing stress is very interesting, but it deals with faceplate removal from the bell by melting the frit which involves much higher temperatures.
I suspect that the problem with the heat method isn't thermal stress, but that the PVA or other material has plasticizers in it. With PVA it's probably water. When you heat it the plasticizer becomes a gas and when trapped makes a high pressure between the cover glass and the face of the tube.
I seem to remember in an earlier cataract removal thread someone saying that bubbles would form as they used the heatgun.
Old 04-09-2011, 07:15 PM
well something is getting nasty, the water is def getting murky looking, and I am seeing life forming in the way of little larve looking nasties, yuk...
