Old 05-19-2011, 11:00 AM
yes it has been restored, on new caps or caps that are not bad it works as is should.
I was responding to the issue of what goes wrong with some of the olded dipped caps.
Old 05-19-2011, 08:52 PM
Originally Posted by mbates14 View Post
Thats why you build a 90V boost converter from a couple of 9V batteries. :-)
I just went back to using my Sencore and Tel-Ohmike. The battery I had was a freebie - found in some military surplus stuff I got at the local hamfest. I have several Lambda supplies capable of putting out 90V, but it seems overkill. Mayble I'll break out my ol' Paco and start using it again. It has an eye tube, and works well, but was another piece on an already crowded bench.
If I still had that Radio Shack Battery-a-Month card....
Cheers,
USN RET 22YRS (Avionics/Cal)
Old 05-19-2011, 09:26 PM
Recapping a cap checker, that reminds me of when I borrowed my brother's VOM to repair mine. It had a shorted protection diode across the meter movement.
