Old 06-11-2011, 01:46 PM
Komet's Avatar
Komet Komet is offline
Very nice set! It seems on the neck of CRT there are two ion traps, I can not see very well
Old 06-11-2011, 02:15 PM
Thanks. It's a dual ion trap magnet. The magnets are connected together.
Old 06-11-2011, 02:25 PM
Originally Posted by VintagePC View Post
If that magnifier is too cloudy/yellowish, this might be the first set you have to give an oil change to! Looks like yours is filled with cooking oil from the colour
Usually they're filled with mineral oil. If it's meant to be changed, there should be a drain screw/plug somewhere.
There is a screw plug on the magnifier. I hope that yellowish color is just on the outside surface though - changing the oil sounds veeery messy.
Originally Posted by TerrySmith View Post
I hope you fix that one, it's nice to see the worst condition set restored!
FWIW,the 6AX5GT is the same pinout as a 6X5 and a lot more robust. If your power trans can handle .4a more current it should work fine!
This set calls for a 5U4 and a 5Y3. I found two 5U4s in it
I looked at the tube location label and it shows a two tube tuner. I never had an Admiral that old. Also, all the power supplies I had, had a 6X5 rect. in the audio supply.
Yes, a 6AG5 RF amp and 6J6 osc. / mixer. Sure looks like it's been replaced though. I wonder what was wrong with the original tuner
Old 06-11-2011, 02:26 PM
Komet's Avatar
Oh, I've never seen anything like this before! Are normal on B / W round screen? Can you post a detailed photo? Many thanks in advance
Old 06-11-2011, 04:13 PM
Yes, the 10BP4 and 12LP4 CRTs commonly used in early B&W television used dual ion trap magnets. Here's a closeup of a 12LP4 from another set.
Note that it would not normally be that far down on the neck. I loosened it and let it slide down while I worked on the set.
Old 06-11-2011, 04:33 PM
VintagePC's Avatar
Tube bug got me 05/2010
Not as messy as with a car - since you can flip the magnifier so the oil doesn't start running out as soon as you open the plug hole. Do it over a sink and keep something handy to wipe up any stray drops, just in case.
Drain in to a container, wipe off with a rag, and grab your new oil and a funnel.
You may want to "rinse" the inside with a small amount of fresh oil 2-3 times to "clean" the insides of the glass. (it washes off the film of old oil that will stay behind.)
Then, fill'er up!
Old 06-11-2011, 10:21 PM
MelodyMaster's Avatar
MelodyMaster MelodyMaster is offline
78s Galore.
In the late 60's I got a 21" Marconi set with 70' tube, dating I guess from 1959, and someone had already replaced the 6X5 with a then-contemporary solid state plugin unit. I can't remember the brand. For the security of the transformer and the whole set I've got no compunction against using a solid state replacement, such as a Weber, even if I'm trying to keep the set original.
I never knew about the double-magnet ion trap. I have a 10BP4 for which I could never get the beam properly hitting the phosphors. Maybe I was indeed using an insufficient single-magnet beam bender. I still have that tube.
Are you keeping ALL those 30AXX's Bob? I always liked the projecting bevel design.
Old 06-11-2011, 10:41 PM
You definitely need a dual ion trap magnet to 10BP4s. Check out the data sheet - "Ion trap maget....External, Double Field Type'
I'm going to keep them all long enough to restore and enjoy them for a while. Eventually, I probably will try to sell some off.
Old 06-11-2011, 11:27 PM
78s Galore.
You definitely need a dual ion trap magnet to 10BP4s. Check out the data sheet - "Ion trap maget....External, Double Field Type'.
Huh, How 'bout dat.. I don't recall such an ion trap being on any of the sets with an original 10BP4.. actually the Phillips had an ion trap 10BP4 and it worked well... I'll rummage through the boxes of TV junk I saved. Important information can slip by. .. I've always loved trains, especially the unique, yet it wasn't until just a couple of years ago that I even knew of the existence of the most interesting of all railroads, the Wuppertal Schwebebahn. So it goes... Another collection I have is literally 100's of TV knobs from the 1950s, dating from the time in the sixties that I was a teenage TV repairman.
Of course, that's the whole point of a hobby.... :-) But remember me... Darn I HAVE to get to Hilliard one of these years!
Old 06-12-2011, 11:08 AM
Reece's Avatar
Reece Reece is offline
Wow, another Admiral for the herd! Better hope that bug-eye doesn't leak! If you need more decals down the road, I've still got the masters.
Reece
Old 06-12-2011, 03:57 PM
Thanks, I'll let you know.
I read the Sams for the 30A1 chassis and discovered that the 'S' suffix in the model number means it used the 94C8-2 turret tuner rather than the earlier A1528 wafer switch tuner with channel 1.
Old 06-12-2011, 04:34 PM
I have all the knobs except the channel changer.
I've seen some photos of early sets where it looked just like the others - no tail. I do have some extras like that so I'll use one for now. The knobs with a tail are a real pain to find.
Bob-
I found a knob with the tail for you. Send me a PM with your address and I will send it to you.
Old 06-16-2011, 11:24 PM
The knob is on its way! It is not perfect, but it is the better of the two I had.
Old 06-16-2011, 11:58 PM
Thanks! I found an original Sams for this set and it does show a channel knob with a tail.
Old 06-17-2011, 03:27 AM
I was just looking at my Admiral today, and its inside label is printed 30A14, with that crossed out and replaced with 30A15. I have read of another of these sets having a crossed-out label like that before, maybe here on VK.
