Old 06-24-2011, 05:45 PM
VintagePC's Avatar
Tube bug got me 05/2010
Someone in another thread had some luck with conductive silver epoxy, especially if they're snapped off too close to the glass to easily solder to.
If the leads are straight, maybe giving them a coat of that would help?
Old 07-08-2011, 04:13 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
Looking at epoxies . . .
I'm looking at epoxies, and I can't figure out how hot the neck of a 12LP4 would get during operation. I'm assuming much hotter than 40 degrees centigrade. Am I right?
Old 07-08-2011, 07:54 PM
VintagePC's Avatar
Yep. Temps probably get somewhere similar to your average light bulb, considering the tubes also have black-body radiation coming from the filament.The leads/glass themselves will of course get nowhere near as hot. I think if you can get something rated for over 150 deg. C you should be ok; the solder usually begins to soften around 200 (and melts at 250), and you don't want to go anywhere near that during normal operation.
Old 07-08-2011, 07:56 PM
benman94's Avatar
Resident Lunatic
The epoxy is going to be on the glass, serving as an alternate lead. What temp. rating should I be looking at?
Old 07-08-2011, 07:57 PM
benman94's Avatar
Resident Lunatic
I guess I don't understand your previous message VintagePC.
Old 07-08-2011, 08:29 PM
VintagePC's Avatar
Anything at or over 150 should do the job. (Yeah, it was kinda buried in the middle of the post )
Old 07-10-2011, 10:02 AM
benman94's Avatar
Resident Lunatic
Thanks. I was actually looking at this paint. My idea is to drop a little bit of the paint where the lead is surrounded by glass, then soldering the new lead to the dried paint. I'd then take some heat shrink tubing and wrap up the whole she-bang to prevent arcing. Finally, I'd wrap up the old leads, then thread on the socket and use a heat resistant adhesive to hold the base on. Solder the base's leads and call it good.
Old 07-10-2011, 10:49 AM
You might want to look at the method Phil Nelson ended up using on his Capehart's CRT. Down around post# 57 onward..
http://www.videokarma.org/showthread...=251233&page=4
Old 07-10-2011, 09:10 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
You won't be able to solder to the paint. They usually have an acetate base or similar which will decompose when you try to solder to it. Then the silver will just fall off of the glass.
Old 07-10-2011, 10:59 PM
The epoxy repair that I did on my Capehart's CRT seems to be holding up, although I haven't powered the tube for more than about 15 minutes altogether, so far. The advantage of the silver-filled epoxy is that it makes a strong physical bond as well as an electrical connection.
Old 07-11-2011, 09:54 AM
VintagePC's Avatar
I wonder if it's possible to make your own conductive epoxy?
I know an old trick if you need thermal epoxy is to just mix heatsink paste+epoxy and it works quite well for general purpose.
Be interesting to see how far you'd get if you got some really fine metal powder and mixed it with epoxy.
Old 07-11-2011, 02:08 PM
Isn't J-B Weld epoxy with metal powder mixed in ? I don't think it's very conductive though
Old 07-11-2011, 07:44 PM
I think you should solder to it even if you have to use hair thin wire from an i.f. coil it will still have less resistance than using an epoxy, or epoxy conductive glue. You can do it with a fine point solder iron, and good rosin cleaner. And the thin wire will not torque the solder joint too much at all as you remount the plug base. Even if you have to get a dremmel tool with a pointy thing on it and dig out some of the glass around the broken wire. Wear a face mask and do it in the garage.
Old 07-11-2011, 09:21 PM
I don't think JB Weld is very conductive, if at all. I have used it to repair phenolic switch wafers that were damaged by B+ arcing.
The silver conductive epoxy is designed for electronic repair. Suggested uses include repairing PC boards.
Old 07-12-2011, 07:25 AM
jeyurkon's Avatar
The silver epoxy is good stuff. While it has a higher resistivity than copper wire, it's still negligible. It adheres really well too. The normal heat from operation of the CRT isn't going to hurt it either.
