Cheers,
Brian USN RET 22YRS (Avionics/Cal) CET-Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! |
My RCA CTC185, built in 1999, has a label on the back that states "Thomson Consumer Electronics, 10330 Meridian Street, Indianapolis, IN." I don't know if that address is or was just a business office; I seriously doubt that the company had a manufacturing plant there or anywhere else that late in the game. My best guess is that the building now having the Indianapolis address, whatever it was being used for by the late 1990s into the 21st century (business offices, administration, etc.), was eventually shut down when Thomson took over operations. The building may have been demolished and the land on which it once stood may now be little more than a parking lot, or it may be a retail store or an office building -- who knows? ![]() . The newest and best feature, IMO, of the CTC203 chassis was probably the remotely mounted tuners. By this time RCA had finally gotten the message as to how much trouble the onboard tuner design had been -- thank goodness. My own CTC185 had this tuner design; I had two repairs done on it: both on the RF antenna/cable port which had snapped off the tuner PC board. The first repair lasted a year and cost $120 (not covered by the warranty); the second, something on the order of $68, again out of my own pocket since the warranty didn't cover that one either. However, the technician who did the second repair (in my home) also took the time to resolder the troublesome grounds around the tuner, which explains in large part why the set still works well for me today, 11 years later. Most other sets with OB tuners developed problems when the tuner ground points broke loose, allowing noise to enter the large "jungle" IC. The chip, which among other things contained the tuner programming, lost all the information programmed into it and had to be replaced -- at greast expense to any set owner whose set was now out of warranty. In fact, the tech weho repaired the antenna port on my set the first time told me that one section of the jungle IC was defective, although I never noticed any problems with the picture or sound, likely because I have never used this set on an antenna -- it has always been on cable, as the OTA TV reception in my area was awful in those days (late '90s) and would likely be 10 times worse today.
Jeff, WB8NHV Collecting, restoring and enjoying vintage Zenith radios since 2002 Zenith. Gone, but not forgotten. |
Charles
Collecting & restoring TVs in Los Angeles since age 10 |
Thanks for clearing that up.
I thought possibly they were the Amish closet sets I've heard about
Military aircraft run 115 VAC, 3 phase 400 Hz and 28v redundant busses.
Evolution... |
| Audiokarma |
yep 32 volts was rural farm wind power. I have an instruction sheet that explains how to change the standard 5 tube radio to kinda work on 32 volts dc.
A 32 volt dynamotor powered color tv....what a current hog that would be! |
I've often thought about that 32vdc Zenith that Charles mentions. Neat to think about a place so desolate that the power lines hadn't made it there yet. I have seen some towns on a map that could fit that description.
I'll have to ask around at the steam and gas shows this summer. There are some guys with a lot of old (small) power plants in running order, mostly Kohlers (which are pretty cool, I think). How big were the 32v Delco units, and what engine typically powered them?
Bryan |
This therad is really interesting! I used to think there were not any CTC-13 or 14 chassis even designed, and also thought that 32VDC areas dissapeared in the 50's. Wow the cool things one can learn on these forums!
Tom C. |
![]() Charles
Charles
| Audiokarma |
Way back in 1984 I found some of the rarest of televisions going to the dumpster. I held many of them for years thinking I'd never sell them. But one by one other things came along. Designing color televisions was a life long dream and it was good while it lasted.. Things change and life goes on.. One time we has 1300 in sales/marketing/engineering. We had a wood model shop, metal model shop, PCB manufacturing and assembly. Two buildings, a total of seven floors. Oh well.. Got a great set of Voice of the Victor's from an old executive that retired to Florida... Enough rambling.... BTW there was a CTC-211 but it didn't make it that far.. |
JBL, I find that sort of thing very interesting. I'm sure many of us would enjoy the stories if you wanted to share more.
Bryan |
A CTC 211? What new things did it offer?
[QUOTE=JBL_1;3007072]I started working for RCA back in 1983 down on Sherman Dr on the East side of Indianapolis. We moved to the 10330 N Meridian address in 1994. It was a brand new complex with two buildings. By 2007 the TV business was on the way out. I left on a severance package in Feb 2007. It was clear it was going down the tubes with Chinese ownership. The last of the TTE offices were closed in Indianapolis just over a year ago. The 10330 address still has some satellite receiver design. Thomson bought Technicolor and then changed the name of the Indianapolis operation to Technicolor.
The building now has the St. Vincent's logo on it, so it's now part of that large hospital network here in Indianapolis. A friend's wife was in the IU(formerly Clarion North) hospital further north up on Meridian & on the way up one can see the former Thomson building on the left side of the road. Also the old 600 N. Sherman drive building looks like it's a sort of "mini industrial park" now, with several businesses now occupying that building. Sad to see what became of RCA Victor, a once great electronics giant-though its longtime chairman "General" David Sarnoff was one of the most ruthless, "go for the throat" old-school businessmen that ever walked this planet.
"Take time to deliberate. But when the moment for action arrives, stop thinking and go in!"-Andrew Jackson |
