Old 09-10-2011, 05:49 PM
I like Your "active antenna" jr-tech.
Wa2ise, that is Monty Python you are quoting isnt it?
Old 09-10-2011, 06:28 PM
Adam's Avatar
Adam Adam is offline
I have one of those 'active' cat antennas too - works especially well on ch1
Old 09-26-2011, 07:46 PM
NowhereMan 1966's Avatar
Slave to 1 Cat
I had one of those myself, she even ran on 120 VAC at 60 cycles. This was my second cat, Pansy. (b. 8-19-1987 - d. 8-27-2006)
Old 09-26-2011, 10:16 PM
I'm not going to let mine run on 120VAC as I suspect that it would shorten her life, and despite some of her schenanagans I love her too much to let that happen. Though she does oscilate (read purr) at 60Hz from time to time, but her aches and pains tend to dampen the amplitude now a days.
Old 09-26-2011, 10:22 PM
If you connect your cat to 120VAC, I think his/her eyes will light up as in that picture even without using a flash!
Old 10-02-2011, 06:19 PM
Slave to 1 Cat
Yeah, I love my cats too, the one in the pic lived to be 19 years and 8 days. She was my second cat, a diluted calico.
Old 10-03-2011, 06:14 PM
Hemingray's Avatar
Hemingray Hemingray is offline
Vintage Geek
I'm gonna guess that these little "antennas" are better on UHF than VHF? I'd have to find one myself to try it out.
Death: Man how old is this TV?, You probably get the DuMont network on this thing!
Old 10-03-2011, 09:55 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
Originally Posted by wa2ise View Post
"If it laid an egg, it would fall down behind the telly"
"They don't stamp animals 'property of the zoo', they wouldn't stay still"
"It's time for the penguin on your telly to explode"...
"They stamp them when they're small...!"
"What happens when they molt?"
"Lions don't molt..."
"No, but penguins do! There! I run rings around you, logically!"
"O-oh! Intercourse the penguin!!!"
Old 10-22-2011, 11:16 AM
Adam's Avatar
I picked up another one of these astro-dogs:
Old 10-22-2011, 01:50 PM
Adam, I'm wondering -- how well do these antennas work in your particular area? I don't know how far you are from the Memphis TV transmitters; however, if you are in a prime signal area I'd guess they would work reasonably well, even for DTV, although you may have to move the antenna around on top of the set (or even to another part of the room) to get a decent signal. The first pic attached to your post shows an Astro antenna connected to a Zenith 12" b&w TV. I don't see a converter box, so I'm thinking the only stations you can receive with that setup are LPTVs (low power television stations) or translators, if there are any in your area.
Old 10-22-2011, 02:13 PM
Adam's Avatar
I'm using them to receive the signal from my own modulator. For this they work fine. But I actually am really close to some transmitters so they will work hooked to my dtv converter. They work about as well as rabbit ears not extended too far.
Old 10-22-2011, 03:41 PM
Well, My "active antenna" keeps growing and increasing in wavelength. Today it is working well even down to the 10 Meter shortwave band. (which is really hot today).
