Old 09-27-2011, 10:27 AM
Reece's Avatar
Reece Reece is offline
They used transformer coupling in these sets as it gives more gain. R/C coupling will generally give better fidelity but less gain; however, you may be satisfied with the volume you get, and on a typical twenties speaker, the better quality may not be noticed anyway!
Reece
Old 09-27-2011, 04:20 PM
stusnyder's Avatar
The volume is really good, in my opinion. I was surprised how loud it goes.
Old 09-27-2011, 07:08 PM
leadlike's Avatar
leadlike leadlike is offline
Are you listening through headphones or a speaker? I've found headphones (especially Baldwin type Cs) much better for critical listening on these 3 dialers.
Old 09-28-2011, 07:12 PM
stusnyder's Avatar
Thru a speaker, with a good range of volume.
Old 09-30-2011, 06:58 PM
stusnyder's Avatar
transformer teardown
Heres some pics of the transformer, the first is the temp circut I hooked up to test the radio, next is the coil of the tansformer. One winding is broken internally. The last pic is all the pieces of the transformer.
What I'm doing now is cutting the center tab out of each plate, so when it's assembled, it will be hollow to mount the resistors and capacitor inside.
Old 09-30-2011, 07:11 PM
leadlike's Avatar
The replacement core should fit on your transformer, as yours looks pretty standard for that era. I've seen little bits of wood used to snug up the fitting between the windings and the laminations. Don't expect a huge difference in performance. I replaced the transformers in a Neutrodyne set, after bypassing the originals with an RC circuit, and didn't notice much of a difference either way.
Old 09-30-2011, 07:25 PM
stusnyder's Avatar
I'm not replacing the core, I'm putting the RC circut inside the transformer case.
Old 10-13-2011, 08:49 PM
stusnyder's Avatar
here's he gutted out transormer with the 2 resistors and capacitor mounted inside. I think it turned out real nice.
