Old 10-14-2011, 12:07 AM
reeferman's Avatar
CT-100 Service manual
Phil Nelson,
I have an original that I could scan for you if you are still looking.
Phil
Old 10-14-2011, 01:39 AM
Much appreciated. I'll send you a PM.
Old 10-14-2011, 04:52 AM
earlyfilm's Avatar
Eternal Member
Originally Posted by reeferman View Post
Phil Nelson,
Phil
Reeferman, If your original is different from the one at
http://www.earlytelevision.org/images/ct_100_manual.pdf
I'm sure a lot more of us would like to see a copy.
James.
Old 10-14-2011, 11:16 AM
The manual at ETF appears to be the same as the 1954 service manual data, which you can also find at http://antiqueradio.org/RCACT-100TelevisionDesign.htm .
Reeferman agreed to scan his manual and email it to me. If it is something different than the field service material, I can publish it with other materials listed in my article.
Phil's Old Radios
Old 10-15-2011, 02:37 PM
Steve McVoy's Avatar
You need to separate the CT-100 from the 21 inch sets that followed in terms of difficulty of convergence. The CT-100 had very few adjustments and convergence is easy to do. Of course the tube only produces a 12 inch picture, so errors aren't as visible.
Old 10-15-2011, 09:20 PM
reeferman's Avatar
CT-100 service manual
Phil,
Here is the cover of the 40 page document. Had to do B&W for size requirements. Sent you a reply to the antique radio address. Let me know.
Phil
Old 10-15-2011, 11:32 PM
earlyfilm's Avatar
Eternal Member
Steve, thanks for the information! I was unaware of that, as these sets were out of use when I started servicing color.
The first shipment, in 1954, of the CT-100s to Western Tennessee was only five sets.
Two of these five sets went to WMCT, the NBC affiliate in Memphis, one set to the home of a senior executive at the station, the fourth set to a Memphis doctor, and the fifth set was purchased by the owner of a TV repair shop 80 miles north of the station, where four month later, I started working repairing radios, cleaning the shop and general odd jobs and slowly graduated to B&W TVs.
Although the CT-100 was purchased through the Memphis distributor, the south bound freight truck actually left his set at his shop the day before the other four were delivered to the Memphis distributor.
When shop owner called about the RCA tech who was supposed to come out to set the set up, he was told he would be up in about two weeks. Since my impatient future boss had owned and operated his shop for 30 years and he had taken the RCA color training course, he said that he would set the set up himself!
Now, this was a statement that he quickly came to regret, as he was never able to get the set working. It turned out that something had jarred loose in the CRT during shipping and the resulting short took out some other components in the set. It was about a month and two trips by the RCA tech before he ever saw a full color image on it. He was never willing to talk about that humbling experience. He kept the set in his shop and used it as a display curiosity, sometimes turning it on to impress a customer. He would not let anyone else in the shop touch that set.
I moved to Atlanta in the spring of 1959 and there my experience on color TV was limited to the few remaining CBS 205's that the other repairmen hated and Admiral 1956-58 models. The Atlanta shop had a contract with a store that purchased a warehouse with 137 mostly non-operational Admiral dealer returns. The store contracted with us for the labor to repair them, with Admiral giving a 30 day parts-only warranty starting with the sale date.
The store kinda forgot to tell their customers that they were buying old used TVs. I switched careers and retired from TV servicing in late 1960, and never looked back. Since then, I've only repaired my own sets and a few for my friends.
James.
Old 10-16-2011, 04:19 PM
A color CRT does have some issues with the earth's magnetic field but nothing that can't be solved with a tech with experience. However, I have never heard of and never experienced any problems with that issue with any color camera. That's a (technicians') wives tale. A properly set up TK41 delivered great color in any position. For that matter, if it were true it would also bother B&W cameras because they used the same basic circuits, pickup tubes and magnetism doesn't bother the color dichroic lens assembly.
julian
Old 10-16-2011, 06:22 PM
The image orthicons are mounted in a metal tube, which I'd guess acts as a magnetic shield, sufficient for protection from the Earth's field, but not necessarily from man-made fields. The Ed Sullivan theater in NY backed up to a subway transformer station (maybe still does) which caused problems if cameras were too close to the back wall. This was still the case in the early 90s when we shot the first US HDTV tests there on tube cameras (Saticons). Don't know if the substation is still there, but CCD cameras make it a moot point for the Letterman show that is staged there.
Old 10-16-2011, 06:49 PM
NYC Rotary Converter
You are talking about a well and overdone subject about a rotary converter near the theater. Rotary converters are no longer used but are still in place. Although I have seen no evidence of that effect, this is an extreme circumstance that would bother anything.
We were talking about the earth's magnetic field, and NOT extreme man made circumstances like that.
As far as the Letterman Theater is concerned, the threat was never much of a problem:
"When the Ed Sullivan Theater was built next door to IRT Substation #13, Lobenstein said CBS made a deal with the IRT; since the extreme radio-frequency energy emitted by the station would make the network’s cameras behave oddly, the IRT agreed to shut down the substation each Sunday evening while Sullivan’s show was broadcast. After CBS moved David Letterman’s show there in 1993, the network inquired about the possibility of doing the same thing for Letterman’s nightly tapings. The MTA balked that time around, since shutting down a working substation each weekday in the middle of the evening rush hour wouldn’t have worked as well. CBS wound up surrounding the entire Letterman stage in a Faraday cage of quarter-inch plate steel to block the RF emissions. The rotary converters were finally de-energized in December 1999, when they were replaced by new solid-state rectifiers, which are much smaller, quieter, cooler, and easier to maintain."
julian
Old 10-16-2011, 07:12 PM
We were talking about the earth's magnetic field, NOT circumstances like that.
I agree, and I think that's what I said.
Old 10-17-2011, 12:29 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Julian, You do recall the content of previous posts before you post? You also repeated my comments on post #15 re: the TK-40-41 color camera setup. Just checking.
-Steve D.
Old 10-17-2011, 03:27 PM
Sorry Steve,
I do type alot and just slipped my mind. I was looking under "Rotary Converters" and there was that paragraph with no reference. I was making a reference that the Sullivan Theater was not bothered much after they worked out a solution. Someone started this thread saying that the color cameras were affected by the earth's magnetic field for which they are not really bothered (practical sense) if any and they got off on that tangent about the rotary converter house off Broadway in NYC which has nothing to do with the earth's field, an isolated incident.
julian
Old 11-25-2011, 07:18 PM
I scanned the RCA CTC2 manual loaned by reeferman and added it to the reference portion of my CT-100 design article:
Here's a direct link to the 16-megabyte manual:
http://antiqueradio.org/art/RCA_CTC2...ce_Data_T3.pdf
Sure enough, this manual tells the dealer how to install the 15GP22 CRT, which was shipped in a separate carton. As Charles noted, another carton in the lower cabinet space contained the yoke, purity coil, & whatnot.
This 40-page manual has more content than the shorter RCA Field Service Manual section for the CT-100. I haven't yet compared the two to look for little differences in material that's duplicated (the schematic, for instance).
Thanks, reeferman. I'll send the original back in a day or two.
Phil's Old Radios
Old 11-25-2011, 07:45 PM
reeferman's Avatar
Phil
You are welcome.
Phil
