Is the truck negative or positive ground? |
It is a negative ground. I believe most positive ground cars were imports.
All the 6V Chrysler product cars i ever dealt with were positive ground also, though there may well have been exceptions.
The truck is actually my fathers, and I will check with him tommorow. I am also going to test it tommorow when the battery is charged again. Thanks for the help so far!
6 volt Fords as well.
| Audiokarma |
Turns out, the truck is positive ground. with the transformer diconnected, I read 307 volts dc to ground. When I reconnected the circuit, the vibrator didnt even run. After a lot of fooling around with it it finally began to run. Unfortunately, the radio does not work. A hum the same frequency as the vibrator came through the speaker, but nothing else. As i turned the tuning cap, there were crackles and pops from the cap itself. It sounded like high voltage arcing between the plates. Should the rotors have hv on them? I know the stator is directly connected to ground. The vibrator really didnt want to start, I had to tap on it and shake it to make it start. I think I am in over my head. Now what?
![]() Quote:
Addendum:
BTW, what are you disconnecting? The break should be at either side of L6, the RF choke directly downstream from C34. That'll be a good opportunity to check for a B+ short 'downstream'. Last edited by old_coot88; 10-29-2011 at 03:28 PM. Reason: typo |
The 307 volts was positive in relation to ground. It was measured with the .1mfd cap connected to the secondary center tap and nothing else. I did replace the electrolytic that died. I didn't think to check the actual voltage on the tuning cap, but I'm pretty sure it was sparking. I actually found that the rotor was rubbing, so I bent one of the plates over a little. I made a mistake in typing, the rotor is actually connected to ground not the stator. When I disconnected the hv circuit again at said point, I got 267 vdc. This may have been due to the tubes being in and drawing heater current, while last time they were not. Once again I had to tap on the vibrator to get it started.
Also a side note: do you think there is a place where Ken-Rad ST style tubes can be found? I would like to have them all match the originals. The 6B8G and 6N7G are replacements.
| Audiokarma |
I assume you have replaced all electrolytic capacitors. If not, do that before any more struggling.
The only capacitors that havent been replaced are three very small value micas that I couldnt find replacements for.
Madmike
Those vibrators with mechanical contacts are trouble. There is a place in florida that makes them exact for your unit in a solid state version. I restored a negative ground 53 Chevrolet radio. A total recap was needed also. According to Justradios.com, mica caps rarely go bad. http://www.radiodaze.com Dave G |
