Old 07-22-2012, 11:39 PM
austvarchive austvarchive is offline
facebook link doesnt work...?
Old 07-24-2012, 12:30 AM
XDCAM's Avatar
XDCAM XDCAM is offline
Thanks Just up dated it .
Old 08-14-2012, 05:13 PM
XDCAM's Avatar
Smile Alive
On our Network News , I saw One of these Camera,s (In Count) that is Going again in Dunedin (Never left Studio ex DNTV) .
Old 08-31-2012, 12:17 AM
XDCAM's Avatar
Can you use Mrk 8 Cable to run a Mrk 4 Camera please ?
Old 09-03-2012, 05:29 AM
BrianSummers's Avatar
BrianSummers BrianSummers is offline
TV Camera Museum Curator
Yes and no! The BICC Mk4b cable and the T1889 cable (the thin stuff with the aluminium connectors known as Mk8 cable) are both wired the same, so the older Mk4 cable can be used with a Marconi Mk VIII camera.
It not so clear cut the other way round. I would not be happy because of the voltage and current ratings of the cable. The Marconi Mk IV sends mains (240v AC) up the cable. and ht at 250 -330 volts. Some of the T1889 cable cores are rated at 50volts dc others are at 400v RMS, it would need a lot of checking and looking at the pin outs for both cameras to see what is were!
I would not do it unless I were utterly desperate.
Old 09-03-2012, 04:05 PM
XDCAM's Avatar
Thanks Brian, I have short length of BICC Mk4b Cable & lots of Mk 8 .
Old 09-12-2012, 10:24 AM
Telecruiser's Avatar
Telecruiser Telecruiser is offline
I have one Mark IV camera head and CCU's power supplies cables, etc. for three. They were a part of my DuMont Telecruiser which came from WFAA, Channel 8 in Dallas. I would love to find at least one more camera head so I could reunite this stuff with the bus. You can see more at www.telecruiser.com and www.chalkhillmedia.org/Museum
Old 09-25-2012, 05:13 PM
XDCAM's Avatar
Is their a page like this RCA one http://www.oldradio.com/archives/har...TV/vmuseum.htm of Marconi / EMI / Phil etc Camera owners ?
Old 09-29-2012, 03:33 PM
I have camera head SN:200. I also have power supply units, CCU's and sets of cables for three MK-IV cameras. They were a part of the DuMont Telecruiser project I'm restoring. www.telecruiser.com I would be most interested in acquiring a second camera head, so I could install two of them in the Telecruiser.
Old 10-02-2012, 03:45 PM
XDCAM's Avatar
Question Cable
Can Somebody please tell me the wiring of the Pulse/Blanking Cable for the CCU input please ?
Old 10-07-2012, 11:26 PM
XDCAM's Avatar
Tv-camera
I hope this went to one of the members !http://www.ebay.com/itm/1958-MARCONI...-/330792222659
Old 10-08-2012, 12:57 AM
ppppenguin's Avatar
I assume you mean the EP8 pulse connector that Marconi often used on their kit. Paul Marshall is the man to give an authoritative answer but I think it's:
Pin 1: Line (Horiz) Drive
Pin 7: Field (vert) drive
Pin 5: Mixed blanking
Pins 3 & 8: Ground
Other pins unused. Mixed sync has its own PL259 conenctor.
Old 10-08-2012, 08:36 AM
I sure wish I'd known about it. I would have paid considerably more than the winning bid.
Old 10-08-2012, 03:03 PM
XDCAM's Avatar
Thanks
Pins 3 & 8: Ground
Thanks for the info .I don't have any paper work on this .
Old 10-08-2012, 03:11 PM
XDCAM's Avatar
Contact
At closer look it is a carcass .If I was you, I would make contact with this seller as he deals in Old Gear .
