Old 08-03-2012, 09:55 AM
ctc17 ctc17 is offline
Also try backing the agc off a tad.
Old 08-03-2012, 10:10 AM
ok ill try that, and i lowered the contrast and its not to bad but it is an old set and i am greatful that it works as good as it does.
Old 08-03-2012, 10:17 AM
well i raised the agc and there it was so i backed it off a bit and it looks good. well maybe i did have it alittle to high.
Old 08-03-2012, 10:29 AM
with this rca ctc16x set i have that i had to sub the tube, if the damper tube is weak would this be a reason for not getting the 3 color lines up in the service mode and crt bias at max or could it only be the boost diode. this has a 3 position bias switch and its at max and the screen is really bright and clear, i guess i could say it does have a perfect picture. i forgot to add that the crt tests very good no shorts.
Old 08-04-2012, 09:57 AM
I doubt it. Usually if those tubes are weak the picture will shrink and pull in from the sides.
Check your DC voltages on the screen pots and make sure the boost is there. Also the bias switch could be bad.
Old 08-04-2012, 11:11 AM
the bias switch has 3 positions and each one seems to work as i get a darker picture as i switch it to the other spots. ill check those voltages, i think around 6-700volts i think. thanks
Old 09-04-2012, 09:09 AM
radiotron's Avatar
radiotron radiotron is offline
johnny the raster master!
hey all yes me again, this 63 silvertone i have has like a ghost bar in the middle of the screen but certain scenes its there others its not. and the colors seem to be brighter on the bottom of the bar then the top and with scenes the bar moves around up and down alittle. its always had it but sometimes its alttle more lately. most old tvs i have seen have this but any suggestions on how to get rid of it. i have changed all the caps in the verticle board so im lost now.
Are you using a vcr if so its probobly flagging.
