Old 09-02-2012, 04:42 PM
jpmad4it jpmad4it is offline
Does the Sony Profeel KX-27PS1 accept RGB via SCART?
Hello all!
My first post right here
I hope I do well!
I am Jonathan from the UK, and I have just purchased an NTSC RGB modded N64. I have been looking at this monitor to use along with my modded N64:
Sony Profeel KX-27PS1 monitor, which you can see here http://www.ebay.com.au/itm/Sony-Trin.../300617930328y - if you look at the second image / read the description it shows the inputs that the monitor accepts. The problem is I don't know if the SCART input would accept and display the RGB signal from the N64. There is a specific 34 pin multi RGB input, but I have no idea where I would get that kind of lead for the N64 (I guess I would have to make my own?)
If anyone could help me answer the above questions I would be extremely grateful.
If this monitor is not going to work, it would be amazing if someone could point me towards one of the compatible sony PVM monitors instead.
I look forward to your replies.
Kind regards
Jonathan
