Old 09-16-2012, 06:43 PM
well it worked but it was for testing purposes only and i put back the glass 3a3.
I would get a good NOS 3a3 anyway.
It sounds like the HV regulation may not be working properly. I would check the shunt tube cathode just to be sure. It also could be that you are just over driving the CRT trying to make it too bright. I am not going to try and explain checking the shunt, you can either read the sams or have someone else explain it.
Old 09-16-2012, 07:01 PM
i have been here befor with looking in the sams for how to do it but for some reason its not in it. so ill look online or ill call a friend of mine and ill have to check it. as far as the RGB drives they are low so i dont know whats going on with it.
Old 09-16-2012, 07:14 PM
kine bias low too? did you go thru the correct grey scale setup?
Old 09-17-2012, 07:05 AM
yes kine bias all the way counter and grey scale is fine.
