Old 12-03-2012, 02:49 PM
DavidGoncalv's Avatar
DavidGoncalv DavidGoncalv is offline
For the folks that have HV output issues, I wonder if they could monitor the RF frequency over time and see if it shifts.
Old 12-05-2012, 04:13 PM
Retrovert's Avatar
Retrovert Retrovert is offline
Originally Posted by earlyfilm View Post
The first cleaner you mentioned has some nasty chemicals in it:
SODIUM HYDROXIDE; caustic soda; soda lye
ETHYLENE GLYCOL MONOBUTYL ETHER; 2-butoxyethanol; butyl cellosolve
SODIUM XYLENE SULFONATE
SODIUM DODECYLBENZENE SULFONATE; linear alkyl aryl sodium sulfonate; Sodium
DDBSA
DIETHYLENE GLYCOL MONOBUTYL ETHER; 2-(2-butoxyethoxy)-ethanol; butyl carbitol
The NaOH isn't necessarily harmful. True, it's a strong base and will chew up your skin/eyes, but in practice one wears eye protection, gloves, long sleeves, and doesn't use it as a dessert topping. Just don't use it to degrease yourself.
Butyl cellosolve is ethylene glycol monobutyl ether (EGBE).
Glycol ethers should give you the willies, however. Not only are they a known carcinogen associated with all sorts of tumors, but they cause testicular atrophy. (Yikes!) And the amount required isn't huge. I believe the EU and Canada tightly regulate their use and may have banned a number of them.
Old 12-05-2012, 04:21 PM
Tom Albrecht's Avatar
Phil, if your coil was known to be bad beforehand, and now appears to be permanently fixed, that would be good news indeed.
I have to admit I would be somewhat surprised if this approach offers more than a temporary fix. If moisture is in fact the problem, there is no polymer coating of any kind that can keep it out for more than a few days or weeks. Polymeric coatings are generally quite permeable to water.
Ability to insulate is mainly a separate issue, so there is no particular reason why a product geared toward good insulation would be good at keeping water out of a coil and preventing the overall lossiness in the structure that results from that. I suspect this insulating coating is a nice choice for reducing tendency for corona, etc.
I've done the clean, bake, and coat approach on a Hallicrafters 505 coil, and found the improvement was only temporary.
However, what did work was to mount a cooling fan inside the HV cage on that same Halllicrafters. Now it works fine.
Previously, the HV would start out OK and then go low after 10-15 minutes. It seemed the combination of old, moist coil and a little heat build up resulted in the fade.
And as I recently reported on ARF, I successfully replaced a Philco coil with a surplus Motorola coil, and am having good success with that.
So far have not had to resort to an alternate HV module.
Old 12-09-2012, 01:48 AM
I've got this set working now!
It looks pretty good, I changed a few out of tolerance resistors, there weren't all that many actually. Still have to get a couple 100k 1 watt but everything else is done.
It had a bad section (short) in that multi section resistor that's riveted to the chassis so I replaced them with some individual ceramic resistors.
The originals were only rated at 2 and 4 watts, the new ones are 5 and 10 watts so they aren't running hot at all, I need to find a way to neatly install them though.
I had miswired a circuit in the HV cage, put a wire where it shouldn't have been and caused a short that dragged the B+ down and was smoking the 680 ohm resistor on the 25Z6, as soon as I cleared that up it started working.
The Vertical is short, swapping out tubes makes no difference, the two 100k resistors I need are in the Vertical circuit, one is reading 179k and the other is 130k, they are supposed to be 10% tolerance so they are badly out of whack.
One other problem is the socket for the 6C4 in the tuner, it's the one on the right front corner, it loses it's heater connection some times, I'll have to replace it or see if it's repairable, I hate replacing sockets, all those wires and drilling out the rivets, ugh.
The CRT I'm using here is shot, I use it for testing just in case something bad happens I won't break a good tube.
In normal light it's unwatchable but the Camera is much more sensitive so it works well for taking pictures
Old 12-09-2012, 09:13 PM
The Vertical height problem was a drifted 680k resistor supplying B+ to the Vertical Oscillator, it had drifted somewhere around 2 meg, now the vertical has plenty of height.
This set has really strong audio!
Posted a short video of it running here: http://vintagetvsets.com/videos/hallicrafters2.wmv I suggest right clicking and viewing full screen.
The CRT is a NOS Rebuilt that I got off eBay, it had a short under the base cap, after removing the cap and straightening out the bent over wire it works great. Removing and replacing the base on a 7JP4 isn't a job I'd wish on anyone, nerve wracking to say the least.
The HV transformer is working great, it's been run a couple hours with no fade.
Old 12-10-2012, 02:37 PM
Can you take an under-chassis photo for me? Just details on the component layout.
Old 12-10-2012, 06:27 PM
Sure can, I ditched all the multi section paper electrolytics though and wired them individually, I was jut not in the mood to restuff the tubes and hunt down new wire for them, it came out quite neat I think.
Pictures when I get home tonight.
One problem I'm still having is some slight streaking in the picture, it gets worse after being on for an hour.
Not sure if it's HV arcing somewhere or some component in the video chain acting up. I can't hear any arcing, it's quite quiet actually and I have all the covers on the HV cage (top and bottom). Possibly a Silver Mica going bad, if this set has any of those, I'm not sure it does.
Old 12-10-2012, 08:27 PM
David, here's the picture, it's too big to post here so I put it on my site.
http://vintagetvsets.com/temp/hallicaps.jpg
The two big caps on the left are way overkill, they were 40@300v but I had some 47@500v so that's what I used, I added the terminal strip and wire to make it neat.
