Old 01-11-2013, 02:13 PM
David Roper's Avatar
console lover
It's going to look like something from the Billy Barty estate. The only practical cabinet for something that size is an upright, like the Sears-Toshiba 16" set.
tvontheporch.com
Old 01-11-2013, 05:43 PM
WISCOJIM WISCOJIM is offline
Originally Posted by wa2ise View Post
If you go to that much trouble, maybe one should consoleize a HDTV flat screen.
Wilkerson makes a nice one.
Old 01-11-2013, 06:09 PM
lnx64's Avatar
lnx64 lnx64 is offline
I have an idea, that consists of a two part console. The base console, that sits on a external stand, made for the console. I'm not going to discuss how this is going to look, but it should look nice when done. I went to lowes today and did some looking around and gathering parts (didn't buy anything yet).
Going with Aspen wood for the console. That's all I'm saying right now.
Old 01-13-2013, 02:40 PM
lnx64's Avatar
Ok, well I figured I'd show my plans a little bit.
The little wooden piece under the TV is removable to gain access to color and tint controls.
Old 01-13-2013, 06:09 PM
console lover
Interesting project, but it's not a console. It could look like one enough to pass, but a couple of alterations are necessary. First, eliminate the visible gap between the TV and the base. Next, instead of shelves, but a grill cloth in the bottom. Hell, why not put the speaker there.
That is a tabletop sitting on a base, looking like a console, which is what you want to do.
tvontheporch.com
Old 01-13-2013, 08:17 PM
lnx64's Avatar
There isn't going to be a visible seam between the TV and the wooden panels. It's going to be right against the TV itself.
It doesn't need to sit on the extra stand with shelves, it's only to just make the tv higher. Without it it would stand normally like any other console.
I've seen many consoles with bezels that look like a regular tv put in a stand, like some RCAs.
Old 01-13-2013, 08:21 PM
lnx64's Avatar
I might base a few of the designs off of this TV.
https://encrypted-tbn0.gstatic.com/i...6DqVcrKSaPLjcg
Old 01-13-2013, 09:03 PM
console lover
Yes, I grew up surrounded by them. But they weren't configured so that you had to get on your knees to tune them. If you already recognize that your TV is too small to be a low boy console I don't understand why you insist on making such a cabinet for it.
tvontheporch.com
Old 01-13-2013, 09:50 PM
lnx64's Avatar
Because it's my TV and I'd like to do something different with it.
That's why I wanted to make the two piece idea. It's a stand, but it just raises the console itself, and can hold things like game systems and VCR's.
Old 01-13-2013, 10:03 PM
console lover
Alternately, you could make it look awesome. Up to you.
tvontheporch.com
Old 01-13-2013, 10:25 PM
lnx64's Avatar
I just want it to be functional to hold equipment under it, with a removable shelf, so that way the top can be clean.
Old 02-18-2013, 05:27 PM
you know if its the gray plastic you are worried about looking at, you could make veneer one or more layers thick to cover some of the upper, and lower parts of the plastic, and it would not add too much bulk or depth to it. You would have to be extra careful with it in those spots........ I'm thinking of putting a big panasonic 34WXJ54 into a cabinet with a stereo and record player, kinda home made air craft carrier..... I think it may be as big as our couch, so its not been built yet.... Plus I'll get to name it..... Like I can call it "The Lexington" or "The Big House" and put a spot for the cat to hide out inside.... I was going to make a veneer edge to cover up some of the plastic, yet try to have it not look like the tv is 3/4" or more behind a wood frame. Keep the entire tv still in its original plastic cabinet, put that inside a wood console with HD rollers, strong wood frame. It may end up weighing more than twice the tv alone....
Old 02-23-2013, 02:08 PM
Norbert Norbert is offline
Banned
I'm confused. How do you gather parts at the store but not buy them? Are you hiding them in the corner of the store so you can come back and "buy" them at a later date?
Old 02-23-2013, 04:50 PM
lnx64's Avatar
No no, gathering parts on paper, like what to buy and stuff for later.
Old 02-23-2013, 08:07 PM
sampson159's Avatar
sampson159
i like the idea myself.not a fan of the set but it can be made to look like a mini console.retro style.i m for it!
