Old 01-14-2013, 12:12 PM
decojoe67's Avatar
Bob, This seems to be a good repo grille cloth for your set! Not exact, but pretty close!
http://www.ebay.com/itm/ANTIQUE-RADI...item5aed3914c8
Old 01-14-2013, 05:05 PM
Thanks, that does look pretty good. I better go for a larger side for when I screw up. Boy do I hate installing grille cloth!
Some people see that Black Goo and just run off screaming and waving their hands in the air.
I can't wait to pull the chassis and get it cleaned off
Here's a closer look at the veneer loss. I've seen pretty good repairs just done with painted on faux wood grain. I guess I could give that a try.
Old 01-15-2013, 04:17 AM
decojoe67's Avatar
I agree. Sometimes grille installation goes like a breeze, other times everything goes wrong!
As far as the finish, I find that darkerening those bad spots is the first step to making them dissapear. Then a little stippling-in if necessary. You've done impressive cabinet work befor Bob. I see this one as an easy job for you!
Old 01-15-2013, 10:44 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
They are pretty sets. I have a rare version with a matching Turntable/Tabletop setup. It has the very first 3-speed Webster-Chicago turntable in a drawer. It was an easy cosmetic and electronic resto:
Shemp & Moe approve!
Old 01-16-2013, 04:14 AM
decojoe67's Avatar
[QUOTE=M3-SRT8;3059375]They are pretty sets. I have a rare version with a matching Turntable/Tabletop setup. It has the very first 3-speed Webster-Chicago turntable in a drawer. It was an easy cosmetic and electronic resto:
QUOTE]
Very nice! That set and the Philco 48-1000 are two of the best examples of that early post-war modern deco look with tabletop TV sets.
Old 01-17-2013, 11:42 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Was that ion burn caused by the "OFF DOT"?
SR
Old 01-18-2013, 12:14 AM
I found it hard to believe, but the 12JP4 doesn't use an ion trap so the burn is inevitable.
Old 01-27-2013, 01:16 AM
bars&tone's Avatar
bars&tone bars&tone is offline
Awesome find! Congratulations!
Old 01-27-2013, 12:56 PM
Thanks. I went with decojoe67's suggestion and picked up this grille cloth. Actually, it's not really grille cloth as it's rather heavy but definitely better than what's in there now.
Old 01-27-2013, 02:02 PM
decojoe67's Avatar
Glad I could help Bob. It at least has the general idea of the original. The reddish color in it actually works with the cabinet color. I think it'll look fine.
Old 12-30-2016, 10:59 AM
I finally got around to pulling the chassis on this beast. Hey it's only been 3 years
It was getting late and I didn't have a chance to take photos under the chassis. I'll do that tonight.
So far it looks to be in good condition and pretty much all original.
066
That melted gasket material sure is a mess! Any suggestions for cleaning it off ? Hoping to avoid using a gallon of paint thinner
Old 12-31-2016, 12:34 AM
Here's the underside - heavy sucker!
Odd place for a tube ?
Hope the power delay relay is still good.
I don't trust candohms
The tuner shaft feels sloppy so I'm assuming the worst - the shaft is broken
Not sure how to get it open to confirm. Seems like the CRT is in the way of removing he screws on the side.
Old 12-31-2016, 09:47 AM
Radiotronman's Avatar
Cool set. It looked liked Dumont made the tuner obviously, but seeing the underside it looks like Dumont made the whole thing. That'll be a great performer once restored.
Old 12-31-2016, 10:14 AM
Kevin Kuehn's Avatar
Workin' Late Again
Heat likely was the cause for that gasket material turning into a lava flow. So I conclude cleaning it on a hot summer day in a 110 degree attic would be helpful. BTW I still don't have my model 125 finished. Way too many projects and not enough hobby time.
Old 12-31-2016, 10:40 AM
I know what you mean. I'm getting ready to move
Acetone had little effect so I got to thinking maybe it's the same gasket material as the Motorola VT71. Bingo, water slowly but steadily dissolves it
