Old 01-23-2013, 01:13 PM
Originally Posted by DavGoodlin View Post
My 1967 Philco 19" color (chassis 17KT50) luggable was found in a trash pile in 1978. Just a 2 watt resistor in the yoke was burned. The transistorized tuner and IF strip in that set was so awesome that it has moved with me 10 times, used in top-floor rooms with rabbit ears. It was a DXing maniac!
It still works but the CRT guns are equally weak and it seems to not like a DTV box for some reason.
Magnavox DTV boxes, don't seem to be old set friendly.
Old 01-23-2013, 01:36 PM
josephdaniel's Avatar
Learning as I go
I wonder why? Just because of strong signals?
Old 01-23-2013, 02:16 PM
radiotron's Avatar
radiotron radiotron is offline
johnny the raster master!
the most durable set probobly a late 50s zenith b/w
my favorate set though is a tie between the kuba komet, and rca victor coffee table set.
now ive owned a coffee table and a late 50s zenith, but not a kuba komet
Looking for zenith cobramatic parts
-johnny the raster master!
Old 01-23-2013, 02:39 PM
wkand's Avatar
wkand wkand is offline
Most durable set
OK, nobody laugh...
A Sampo (Not Sanyo) 19" color set purchased from a now defunct Seattle area discount warehouse (Jafco) in 1980. The jungle IC went out in it after about a year. I broke all the rules and re-soldered the new IC back into the set instead of "socketizing" it.
I paid $200 for the set new, and $12 for the IC. That set saw minimum 10 hour per day use until 2002, and still worked except the CRT was getting tired and badly out of focus. My father used the set exclusively during that time. He liked to turn the set on first thing in the AM, then get coffee and a shower. He leave it on if he went anywhere, except for turning it off while at work.
I hope I did not post this already. If I did, I declare "senior moment", and sincerely apologize.
Old 01-23-2013, 02:44 PM
Looking back, probably the most durable set, both in terms of build quality and longevity, was a Zenith. Don't remember the model or chassis number, but it was an early-60s VHF-only, metal cabinet table model 19 inch. Power tranny with 3DG4 rectifier, 90 degree CRT with BIG NECK (as opposed to the more common 110 degree, small neck). Used it for 5 years and gave it to a widow lady who used it with a UHF converter for many more years till she passed away. The set never needed service or had the back off.
Old 01-23-2013, 06:40 PM
AFAIK, that model was the only Zenith that used that CRT.
Are you sure that it used the 3DG4? All the Zeniths I saw with that CRT used the rare 5BC3, novar based 5U4 equivalent.
I've been wrong before, maybe once.
Old 01-23-2013, 06:59 PM
Geist Geist is offline
Hi All;
The only set that I have known for that long, was the second Set my parents had.. It was on almost daily by me.. It was a B&W, I think Magnovox, somewhere between late 50's and Early 60's.. It had Stereo, But I am not sure when that came out.. I was a TV in the middle.. Speakers on each side, with Phono on upper Left hand side.. With AM/FM radio and Tuner on the Upper Right hand side.. I remember it have a TV Repairman come out, but most likely for a Bad Tube.. Its Demise, came when I Thought it would be an easy job to comvert it to color.. So, I took the B&W set out and tried to put in a color chassis, I had scrounged up somewhere.. Needless to say it went to the basement and our living room had a big empty wall..
THANK YOU Marty
Old 01-23-2013, 07:56 PM
...Are you sure that it used the 3DG4?
Yeah. Unless i'm losin' my marbles (which is entirely possible)
The reason it sticks in memory is that it was the first 3DG4 I'd ever encountered. Maybe another oldtimer could chime in as to whether yea or nay.
Old 01-24-2013, 05:26 AM
Charlie's Avatar
Charlie Charlie is offline
On Land
Philco Diamond D
So far, my most durable has been this '57 Philco Diamond D set that I recapped back in 05 a few weeks before Hurricane Rita. So far, other than removing the safety glass to clean off the CRT, I have done no further repairs to the set. It's been used very regularly since 05... sometimes running 12+ hours a day.
The Philco is the set on the bottom. the top set is a '59 Motorola.
Charlie Trahan
Old 01-24-2013, 08:23 AM
The set just struck me as being an odd model. The higher priced models used the 110 degree CRT and the 3DG3.
IIRC, that set is the only model that used a 19", 90 degree CRT. Zenith could do anything they wanted, as they owned their own CRT plant.
Old 01-24-2013, 09:16 AM
Hah. Never realized it was such a one-off model before. It was sure heavy, built like a tank, and acted as if it could run forever with zero service.
Old 01-24-2013, 11:43 AM
Hi All;
Isn't that what made Zenith and gave them a Great Trademark.. At least during the 50's and earlier.. I can't say about their later stuff.. When you had a Zenith, even Considering that it would last forever.. If you wanted a second set or a friend wanted a referral.. Zenith owners were glad to do so.. They liked their tanks, except at moving time..
THANK YOU Marty
Old 01-24-2013, 12:45 PM
truetone36's Avatar
electronics packrat
I would have to say the most durable set I've had is the 15" Zenith b/w portable that my grandma bought new about 1974 or '75. She used it for the rest of her life and I've had it since she passed away in '86. It's worked flawlessly nearly 40 years and has never had the back off.
Old 01-25-2013, 09:17 AM
Originally Posted by Geist View Post
Hi All;
THANK YOU Marty
I was never too fond of the Zenith sets built before 1958.
Most people didn't like those big clunky tuners, even though they were built well.
I think Zenith realized, when they made the 1956-57, donut chassis, that they weren't service friendly. In 1958, they started the Service-Saver design and the rest is history.
Old 01-25-2013, 09:28 AM
radiotron's Avatar
my 59 zeniths been working great since i got it unrestored exept the horizontal problem but i already have that part
