Old 03-16-2013, 08:52 PM
kramden66 kramden66 is online now
Is it a 21" or 17" ? , what zenith do you have and what parts do you need ?
mike
Old 03-16-2013, 10:29 PM
josephdaniel's Avatar
Learning as I go
I think it was a 17 inch set but I forgot to take a picture when I found it...
I don't remember what model the zenith is but it is one of the sets with the vertical chassis that blocks the entire view of the CRT except for the yoke. all I think it needs are a few tubes ( forgot which tubes too) one paper cap and a electrolytic cap that I have been meaning to put in for a while. It also needs the brightness contrast vert. hold and horozontal hold hooked back up
Old 03-17-2013, 11:10 AM
Learning as I go
I hot the set its a 21 inch set hoping the CRT tests good!
Lebe dein leben für dich selbst
**Searching for any all tube or hybrid or color portable sets would consider some early solid state color too**
Old 03-17-2013, 02:26 PM
bars&tone's Avatar
bars&tone bars&tone is offline
Congratulations!!!! A Predicta "Holiday" was well worth it, imho.
Old 03-17-2013, 04:02 PM
StellarTV's Avatar
StellarTV StellarTV is offline
Absolutely. Nice buy!
Old 03-17-2013, 04:44 PM
If you got that for $130 or less you did really good! Looks like it has all the knobs which is often not the case.
The stuff on the inside of the screen is just mold on the plastic, it'll clean right off, I don't see any cracks in it.
Old 03-17-2013, 04:46 PM
Learning as I go
no cracks whatsoever and I got it for under 130. I do have one question how do I remove the plastic screen over the CRT?
Old 03-17-2013, 05:40 PM
StellarTV's Avatar
Remove the brass 'bowtie' underneath the front of the screen being held on by two brass screws. Unhook the spring from the decorative brass colored plastic trim and remove, and then remove the two screws in either side of the CRT 'neck' holding on the thin metal strap. This holds both parts of the shell together.
When you reassemble, replacing the decorative plastic trimpiece can be a bear if you try to hold it in place while hooking it back onto the spring. Easy way is to hook both ends back on the spring and 'slide' the trimpiece back over the shell until it snaps into place.
Old 03-17-2013, 06:02 PM
Geist Geist is offline
Hi All;
Joseph, Great catch !!! Glad You got it..
Go look at Bob Andersen's site and check out His Predicta's..
I don't know which one, but one has the removing the collar you are asking about, its always better to watch someone else do it first, so You have an Idea of what to do..
http://www.youtube.com/watch?v=R7IWv...5PgZx_&index=1
Half of the caps being replaced, will make it easier on you..
It won't be long before this will be The TV for your Bedroom..
THANK YOU Marty
Old 03-17-2013, 06:21 PM
Learning as I go
I plan on reading everything I can find on the web about Predicta's and early PCB's and their problems. I do have a few more questions though when I do feel comfortable to remove the PCB would it be worth while to to replace all of the resistors and networks on the board since they are such a pain to get out and can novus plastic polish be used on the plastic screen cover?
