Old 07-26-2013, 04:12 PM
Ok then back to the orig question how to correctly apply a tension band. Maybe someone that knows how to contact Scotty could fine out?
I know I would feel a lot more comfortable with a tension band on a bonded face CRT (when removing the lens that is), esp after my latest attempt, it sounded like a IED going off in the back yard, I was lucky, only got a minor cut on my arm, there where some pretty big chunks of glass several feet from the implosion.
I think they were tension banded before they were evacuated. A lot less danger them.
The rebuilder that I was buying from several years ago, was doing the same thing, that a lot of you V-K members are doing. That is, using Scotchmount type tape and clear silicone sealant.
It's not a true implosion protection, as the glass panel is not tempered. The nasty resin is what provided the implosion protection.
Old 07-26-2013, 08:06 PM
I see a little education is needed here. I have over 20 + years experience in the tube rebuilding field from a plant that used to be here in Knoxville, Tn. and 20 more just hanging around because he was my friend.
LISTEN UP------DO NOT EVER TRY TO SAW OFF A PRESSURE BAND ON A LIVE TUBE!!
REPEAT---------DO NOT EVER TRY TO SAW OFF A PRESSURE BAND ON A LIVE TUBE----OR YOU WILL BE VERY SORRY!!!!
ALSO DO NOT EVER PUT A TUBE IN THE COOKING OVEN TO BE EVACUATED WITH A PRESSURE BAND STILL ON THE TUBE. THE STATEMENT FROM dieseljeep ABOVE IS FALSE.
THE SAME RESULT WILL OCCUR ON BOTH WARNINGS IF YOU DO NOT HEED THEM! BOTH STATEMENTS ARE GUARANTEED 100%
I KNOW OF TWO AMATEUR "TV REPAIRMEN" WHO THOUGHT THEY KNEW BETTER THAT WISH THEY KNEW THESE TWO FACTS YEARS AGO.
LARGE CRT'S ARE NOT TO BE PLAYED WITH IF YOU DON'T KNOW WHAT YOU ARE DOING. EVEN SCRATCHING A CRT IS VERY LIABLE TO CAUSE IT TO IMPLODE and we always disposed of scratched tubes.
julian
Old 07-27-2013, 07:07 AM
Julian, please elaborate on the correct way to tension band, I like that idea, just not sure how to accomplish.
I can assure you I have no intention of removing one (tension band) from an existing CRT. roger got the message
Old 07-27-2013, 08:58 AM
[QUOTE=julianburke;3077081]I see a little education is needed here. I have over 20 + years experience in the tube rebuilding field from a plant that used to be here in Knoxville, Tn. and 20 more just hanging around because he was my friend.
I have a poor track record this year!
I was wrong twice already.
Old 07-28-2013, 12:44 PM
Pressure banding
Pressure banding was a rather easy finishing step. The outside faceplate was wrapped with a clear plastic tape much like packing tape. The banding material was steel package strapping and we used a Pneumatic Strapping Tool Air Bander Strap Tensioner and I forgot what it was set at but it was very tight. We used a jig to hold the mounting ears in place. The theory is that if the side of the tube cannot expand, and the faceplate is hit, it cannot implode. Striking the faceplate makes the sides expand and it will implode unless the strapping prevents that.
After the tube is let down to air (nitrogen) the pressure band is now removed; not just the fact that it has to be removed before evacuating & cooking but this has to be done so that it fits perfectly into the vertical lathe to weld on some new neck glass stock and to insert the new gun mount and annealing to the button on the gun mount. You cannot make the tube turn true in the lathe with the band still on it.
For some reason if the strap is suddenly cut on a live tube, the sides will expand suddenly and unevenly which will almost guarantee an implosion. I have seen this happen several times by repairmen trying to remove the mounting ears to fit in another application which results in disaster!
julian
