Old 07-20-2013, 11:49 PM
Visual's Avatar
Visual Visual is offline
Output. "Sound multiplex
Exclamation VIDEO DATA SYSTEM- the vcr`RDS`system by vps
http://www.youtube.com/watch?v=Z_7Vg...etailpage&t=77
The
GV-698+
incorporates
WSS
signal (
Wide Screen Signaling
) in 8 formats,
FLOP-TELETEXT
in four languages and
VPS
and
PDC
signals for four countries. All
these signals are individually selectable
Easily programmable PDC and VPS
PDC and VPS test facilities are available optionally with the teletext option. Both systems use control information transmitted with the program to start and stop recording of that program on a VCR. For optimum flexibility, you can use any of nine coded PDC or VPS signals and both types of signal can even be transmitted simultaneously. When testing PDC, you can program PIL (date & time), CNI (country & network), PTY, PTL and the program name. You can even test multi labeling. In VPS mode, you can set information on date, transmission time, country indication, TV channel, stereo/dual/mono sound, adult/general program content and the program name. Special PDC and VPS signals such as timer control code, recording inhibit/terminate code, interruption code and continuation code are also available. Programming of the codes for both PDC and VPS is simple, using the instrument's large display and softkeys.
VS-680VPT /HRS9000EG/!!\A-GX1/!\HR-Z1
