Old 07-27-2013, 08:43 PM
BigDavesTV's Avatar
BigDavesTV
Congratulations, that's a very nice "Sylvie" roundie! :-)
Old 07-29-2013, 12:42 AM
technicolor's Avatar
technicolor technicolor is offline
go big or go home
here are those color stripes
Old 07-29-2013, 08:46 PM
nasadowsk's Avatar
Damn does run fast…
Looks like you're not locking onto the burst.
Old 07-30-2013, 07:44 PM
Bill R Bill R is offline
If there are 6gh8 tubes on the chroma board, replace them. Then check the solder connections to the chassis ground stakes. Could still be something else like bad crystal, tube, or caps, but I start with these first.
Old 07-30-2013, 08:56 PM
In regard to ground stakes, this is preachin' to the choir for sure here, but can't be sed often enough. Always re-flow the ground stakes on the far right end of the chroma board. Although not related to the color sync problem, when these two go open (and they will!), it kills the heaters on the 6GU7s.
When that happens there's a cascade of unsavory events. The 6GU7s' plates go 'waay positive, driving the CRT grids positive (since they're direct coupled). CRT beam current goes into avalanche, lugging the HV down. Picture blooms, goes out of focus and then fades out. Yet the 3A3, flyback, and 6JE6 are still getting hammered with overcurrent and overheating. If you don't catch it in time it can be a real meltdown... just because of those 6GU7s' heaters going out.
This ground stake problem was endemic in the CTC-15, 16, 17 and 25 before being corrected.
Old 07-30-2013, 10:30 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Same goes for mid-60's Maggie color sets as well!
