Old 09-11-2013, 06:52 PM
Originally Posted by 6GH8cowboy View Post
Wow Dave. Pulled two to replace it, got a phone call, finished replacing the Vert cathode cap. Just looked on the bench and there the two 1s at 450 layin there. Think I can slide the chassis back enough to do it in set. That could well be the source of the extra positive on the Vid-Out grid. Didn't notice any neon lamps in there, maybe a production change along the way
Thanks
look on the grid of the blanker tube, they do not show on the pcb, so prob in that chroma hand wired area. Hopefully the cap will take care of it.
Old 09-13-2013, 01:04 PM
6GH8cowboy 6GH8cowboy is offline
Brightness solved
Turned out not to be too much positive voltage but, not enough negative. Someone replaced two resistors R-64 and R-135 (Sams) with values that in total equated to three times the original value. There was not enough negative voltage getting to the brightness control to pull it back enough from positive, thus the sky high grid volts. One of these was on a terminal strip on the top rear of the chassis. This was a factory location but seem like an odd place for it.
Next stop is the seemingly high Horiz cathode current @225 ma. Sharp dip when adjusting the eff coil and drive and grid bias is good. May be possible aged transformer that will have to be tollerated.
Old 09-13-2013, 03:36 PM
holmesuser01's Avatar
Mine has the neon bulbs. The wires to them were broken when I got the set, so I replaced them with new NE-2 lamps in 1975. Now and then, I can see them lit.
