Old 10-23-2013, 09:27 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
This could be explained by the tubes drawing twice as much current on the various anodes, and shifting the voltages on the resistive divider network accordingly. Not really a meaningful data point, I'm afraid...
Old 10-23-2013, 10:27 PM
Tube Radio's Avatar
Tube Radio Tube Radio is offline
I suspect that is what's happening. One way is to confirm by trying that experiment again and measuring the voltages.
In a way that leads me to suspect that if the 5ADP* CRTs are indeed bad it may have something to do with the focus electrode.
Main system
Scott LK-72A amp & LT-110 tuner
Garrard Zero 100C turntable
AKAI GX 255 RTR
iPod & computer
DIY speakers (upgrading them soon)
Old 10-23-2013, 11:03 PM
bob91343 bob91343 is offline
I have what I believe to be a good 5ADP1 if anyone is interested.
Old 10-24-2013, 11:52 AM
earlyfilm's Avatar
Eternal Member
This is a very long shot, but I ran in to it on a DC-coupled scope many years ago.
Measure your CRT voltages both with and without a signal applied to the vertical input.
If anything except for the deflection plate voltages change, suspect something is amiss in the DC coupled sweep amplifier that causes it to pull too much current and create a power supply voltage drop that is causing the CRT to go out of focus.
Jas.
Old 10-24-2013, 03:53 PM
Tube Radio's Avatar
I can try that, but why would the 5CP1A CRT not go out of focus and why would two identical scopes have the same exact problem?
Main system
AKAI GX 255 RTR
iPod & computer
