Old 01-18-2014, 07:06 PM
I have replaced all the Electrolytics, recapped the Horizontal board and most of the Vertical board and now have a nice stable picture.
There are some white ceramic tubular caps on the vertical board I haven't changed yet, they are 10% tolerance Elemenco's.
I suspect the yellow caps we use are probably also within that tolerance but I think I will order some better caps from Mouser for that circuit since vertical is always troublesome with thermal drift and linearity issues.
The image is so good I may skip recapping the video circuits for now, it has sound also and I don't want to screw up the alignment.
This is running an 8" test CRT.
Old 01-21-2014, 09:00 PM
This set has been a really easy restoration, probably because it was refubished in 1964 and probably run well into the 70's.
It started with a raster, new electrolytics and papers in the Horizontal board got me a good image, most of the rest didn't affect it much and there are still three old caps in it that I don't have on hand.
Picture is really bright and sharp, picture really doesn't do it any justice.
Sound is loud and clear and I didn't have to fiddle with the i.f. cans at all to get it that way. this is the Deluxe chassis which probably helps the performance too.
I had to fabricate a new yoke cover centering ring retainer because the old one rotted to dust.
The centering ring does nothing so I shouldn't have spent so much time on it. The centering is fine anyway.
Old 01-21-2014, 10:38 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
The centering is excellent. Nice job, Eric!
Old 01-22-2014, 12:42 AM
The centering magnets should have an effect...Assuming they did not get degaussed over the years.
Old 01-22-2014, 01:00 AM
Kevin Kuehn's Avatar
Workin' Late Again
I'd have to take mine apart to verify, but I think Eric's may have something missing from it's centering ring assembly. It sure seems like it needs to be able to modify that large permanent magnet behind it.
How can a piece of aluminum alone do that?
Old 02-02-2014, 08:03 PM
I'm pretty much done with the electronics on this set, it works really well!
It's been playing Gilligans Island for the last few hours while I worked on other stuff so I made a short video to show it off.
http://www.youtube.com/watch?v=XC-KLSxT02I
