Old 03-12-2014, 06:58 PM
robert1's Avatar
robert1 robert1 is offline
Originally Posted by Phil Nelson View Post
After about 90 seconds on the tester, the needle cruised up into the happy zone.
That's typical of any C.R.T. that has sit unused for many years.. it usually takes about 15 miniutes of warmup time for it to come up to full emmission.
It may not be the greatest tube on Planet Earth, but I'm betting it will make a picture. I'll set the brightener aside and try the set bareback when its turn comes.
by the looks of the meter, that appears to be a strong healthy tube.
you may need to examine that "brightener" to make sure that it is not a 1:1 ratio isolation transformer. that tube may have had a intermittant fil to cathode short.
Old 03-12-2014, 07:10 PM
robert1's Avatar
Does this set use a 5U4 rectifier?
i would love to have this set to restore. sets like these are non-existant in this area.
That is a nice find.
Old 03-12-2014, 07:14 PM
That power transformer looks a little too small to do anything other than feed heaters. And I don't see a 5U4. Just be sure it's not a hot chassis. Or take the appropriate care if it is.
Old 03-12-2014, 08:00 PM
No rectifier tube.
Old 03-12-2014, 09:14 PM
No rectifier tube.
The set looks like a cross between a Hallicrafters, Crosley, with a little Motorola mixed in. It is a hot chassis.
Old 03-12-2014, 09:31 PM
Zenith26kc20's Avatar
I think it looks great! three IF stages, not two! Not as cheap as it could be. Insides look clean! Show us the chassis underneath when you can!
Old 03-12-2014, 10:31 PM
I replaced a couple of bad tubes and ran it up to about 100 volts on the variac (hey -- do what I say, not what I do ), when what to my wondering eyes should appear, but a bright green glow in the CRT neck.
What the heck? The glow comes from what looks like some kind of schmutz on the tube element.
This is without using the brightener (or should I say Britener?).
At roughly 100V the TV produces fine audio, which is mildly encouraging.
The ion trap magnet was originally far back against the tube base. I slid it forward out of curiosity and found that it has a slight effect on the green glow.
Never having seen a green glow outside of a magic eye tube -- this looks exactly the same shade, by the way -- I am most curious.
Old 03-12-2014, 11:28 PM
I seem to recall reading something about CRT makers using some type of marker for lining up the Ion trap, since this seems to be directly under the trap I wonder if that's what this is?
Obviously not gas because that would be purple and between the elements, this almost looks like it's something (phosphor?) applied to the outside of that part.
Old 03-12-2014, 11:39 PM
It definitely looks like a patch (or maybe stripe?) of something on the outside of that element. Possibly the same kind of green phosphor used in magic eye tubes or green CRTs?
For what it's worth (maybe nothing), the ion trap was originally not in that position. It was way back against the tube base and rotated about 30 degrees. Of course, someone might have monkeyed with it before, although the set doesn't show any obvious signs of tampering and the cover does have an AC interlock.
Old 03-12-2014, 11:40 PM
I'm guessing that green p-1 phosphor has been applied to the outside of the anode barrel to provide an indication of proper ion trap adjustment... minimize the scattered electrons = minimized green glow = max beam current down the gun to the screen. Just a WAG, however.
Old 03-13-2014, 12:01 AM
That's pretty much what I recall reading, never saw one with it before though.
Maybe it's peculiar to this one brand, or rebuilder?
Curious how it can work being on the outside of the metal cylinder, unless it works by the cylinder becoming charged when the beam is hitting it instead of going down the center?
Old 03-13-2014, 12:04 AM
Phil, you never said if you got a raster or not?
Old 03-13-2014, 12:51 AM
Found this in a Rauland patent for a electrostatic focus CRT:
it has been found essential that the electron beam be centrally directed along the axis in its passage through the focusing system. In other words, the ion trap must be precisely adjusted for satisfactory focusing with a low-potential electrostatic lens system. Such precise alignment of the ion trap is facilitated by providing a fluorescent coating 29 on the outer wall of second accelerating electrode I6. This fluorescent coating serves as an ion-trap adjustment indicator; in practice, permanent magnet 21 is -moved both axially and rotationally until the glow from fluorescent coating 29 is reduced to a minimum, thus indicating precise ion trap alignment.
https://www.google.com/patents/US2627047
Old 03-13-2014, 01:10 AM
Wow, that's interesting. I wonder if this could be a Rauland tube? I don't see any labeling on the base or what's visible of the neck.
The first time I tried the ion trap, I could clearly see the glow brighten or darken at various positions. (One practical drawback of this scheme is that the room needs to be nearly pitch black to see the green glow. I hadn't noticed it until I turned out the room lights in an effort to catch any glimmer on the screen.)
I don't have any hint of raster, or any sound of HV spooling up, although I'm not sure I can really hear that anymore.
I retried the set without the brightener, just for kicks, and guess what -- no green glow. I moved the ion trap around and suddenly there was a brilliant flash of green all the way around that tube element. Now there's no glow, with or without the brightener. So who knows, maybe that trace of green phosphor just made its last gasp, or for all I know there's a loose wire in the CRT cable.
Tomorrow I'll pull out the chassis and do some more sensible investigations, clean the tube pins & controls, etc. I'm wondering what sort of tuner this thing has, among other things.
Old 03-13-2014, 01:32 PM
Here is a quick peek under the 7M112 chassis. It's uncluttered and it should be easy to work on.
The set has two selenium rectifiers and a sturdy (and clean!) turret-style tuner with 6J6 and 6BK7 tubes. The HV output section is also under the chassis and I removed its (solid steel) cage for this photo. The TV actually has 18 tubes including the CRT, even though only 15 are shown in the back-cover diagram.
Someone serviced this TV not too long ago. Notice the new resistor under the 1B3GT HV rectifier socket. I have exactly the same type of resistor in my parts boxes.
Here are a couple of other recent replacements:
The electrolytic is piggybacked in parallel with a can electrolytic rather than taking the old cap out of circuit. I found another new electrolytic wired between two pins of the 6AH6 video amp. The red Big Chief cap looks like an older replacement. The original paper caps are a brand that I hadn't seen before: "Good-All Marbelite."
I made a couple of cursory checks and the B+ voltage seems reasonable. HV measures only 8.5KV, where that CRT normally wants something like 14KV.
The TV is still full of ancient electrolytics and paper caps, so I'm not going to burn a lot of time diagnosing specifics until it has been recapped. Lacking a good place to work, who knows when that will happen?
It's interesting to peek underneath, anyhow. Yes, it's an inexpensive, series-string set, but the factory wiring is tidy and the overall build quality looks decent. It's surprisingly sensitive, all things considered. When I first powered it up, it made very clear audio receiving a signal from my in-house transmitter, without anything connected to its antenna terminals.
Phil's Old Radios
