Old 03-16-2014, 10:52 AM
robert1's Avatar
robert1 robert1 is offline
Originally Posted by Chip Chester View Post
Here's an example of a hardware method of conversion. Composite for color, and maybe the Luminance only signal from s-video for monochrome.
http://www.monoprice.com/Product?c_i...seq=1&format=2
Chip
that a good device for surfing the web with (if you want to use your TV as the monitor), however, it still requiers a R.F modulator as well as a patch cable to connect your Sound card output to the modulator. also, another problem to think about is resolution. will the video properly be displayed on the TV in the proper 4.3 format?. i really don't think it will.
Old 03-16-2014, 12:11 PM
kvflyer kvflyer is offline
Most computer graphic cards will allow you to set many different aspect ratios. For that matter, how much stuff today is formatted for 4X3? Lots of shows, especially movies are all over the map.
Still, this looks like something to have. Not expensive...
Old 03-16-2014, 01:39 PM
Some PC's have composite and or S-video output on their graphics cards. I have a 2002 HP that does. I found it on the side of the road missing it's hard drives and part of the case. After replacing the missing hardware and building it into a gutted VCR case all I needed to connect it to my modulator was a 1/8 phone jack to RCA adapter (which I have several of laying around) and a single RCA patch cord. I'm half tempted to wire the guts of a wall wort powered modulator into my unit to make it a stand-alone internet/digital to vintage analog TV media box.
Old 03-16-2014, 01:53 PM
The device I noted has horizontal/vertical positioning (hardware) buttons on the side, and apparently various zoom settings as well. The menu would reveal all, of course. Aspect ratio would come from the content itself. You might be able to influence that by changing what screen resolution the computer thinks it is using. And yes, an RF modulator is still required, as referenced post 7.
There are other, similar boxes out there that do this, too. If you really want to go back, the original PC XT monochrome card (plus parallel port) had an RCA mono out. Getting one spiffed up enough to get on the web and browse YouTube would require a little more work than just slappin' some Trumpet Winsock on it.
Chip
Old 03-16-2014, 06:13 PM
TVTim's Avatar
TVTim TVTim is offline
Maybe I missed it but how did you record YT??
I can't figure out how to download YT to copy to a DVD.
Old 03-16-2014, 07:25 PM
robert1's Avatar
That's Easy. Downloading is the easy part, but it requires The Firefox Web Browser along the Video Download-helper Add-on. you can find that add-on clicking Tools-Addons - type in Download-helper. once installed. click to enable it. after it is installed, any you-tube (or other supported video sites), a little icon that looks like three color balls that are spinning will appear on the navigation bar, click on the arrow that is just right of the bar & it will present a drop down menu. choose Quick Download. there will be a choice of filetypes (Medium)-.mp4, (HQ)-.flv click on the (medium).mp4
after your done, go to "Downloads" directory & look for a folder called "dwhelper" that is where your video has downloaded as a .mp4 file.
i do not know much about Microsoft Windows as where they would keep the default user downloads directory as i have not used Microsoft Windows for 10 years. i do all my DVD Authering, & Video Conversions on Linux. i do not know if there is any free software for Video conversion for Windows.
Old 03-16-2014, 07:30 PM
http://download.cnet.com/YTD-Video-D...-10647340.html
Old 03-16-2014, 07:40 PM
robert1's Avatar
That is Spyware. Do Not install. some of the "adware" in that installer cannot be safely un-installed.
also, it does not have the facillity to convert .mp4 to a DVD complient file structure.
Old 03-16-2014, 09:01 PM
bigaudioal's Avatar
Originally Posted by robert1 View Post
there are several ways of achiving this but the best way i found was to just actually burn DVDs of the You-Tube content & play it back on your DVD player. You-Tube has a lot of classic TV shows from the 50's, 60's & 70's as well as classic movies from the 30's up to the 90's. many of them are full length.
i strongly suggest that you use a Linux PC because the process would be actually easer to do then if doing this with a Windows PC.
i do this with Firefox with the Video Download-helper add-on.
i use a easy to use, free, DVD authuring / conversion program called DeVeDe to create the DVD image & use K3B CD/DVD burning program to burn the DVD image to a DVD.
once done, it has great results.
Only issue with burning YT content to DVD is if you want to watch something that is too long to be burned to 1 dvd. Like a 3 hour 1952 World Series game.
For the shorter stuff, like 30 minute TV shows, etc., I also burn to DVD.
-Al
Old 03-16-2014, 09:58 PM
robert1's Avatar
i don't have that issue with my DVD authoring program, i can fit 6 hours of programming on a 4.7G DVD.
when i make DVDs of half hour shows, i can put 8 Half hour shows or put 6 one hour shows on a 4.7G DVD. the DeVeDe authouring program is very flexable & has a lot of options for customisation.
Old 03-16-2014, 10:01 PM
bigaudioal's Avatar
Oh cool!! Thanks for that tip. Have to check that out!
-Al
Old 03-17-2014, 01:54 PM
robert1's Avatar
you will need a Linux PC for this particular app. any modern Linux distribution will do. the apps name is called "DeVeDe" and it is available in the distributions software repositories & in installed with the distributions package manager. i do not think DeVeDe has been ported to Windows.
Ooops, My mistake..they do have a Windows port. i cant vouch if the windows version would have the same feature parody as the Linux version.
heres the link. http://www.devede.org/download/choose/
Old 03-17-2014, 04:36 PM
bigaudioal's Avatar
I downloaded the Firefox down-loader add in and the windows version of DeVeDe and the same 3 hour 1952 World Series game fit on one DVD. About 2.5 of the 4.7 gig. So worked great!!! Thanks for this. Always nice to be able to use multiple devices and techniques to keep cool programming pumping through our vintage sets.
-Al
