Old 02-15-2016, 08:07 PM
HighHopes HighHopes is offline
HighHopes
On an unrelated topic, the DC equivalent rating of a DC cap is 2.8. A 100 VAC cap can take a 280 voltage swing. That is what a 100 VAC voltage does.
HighHopes
I think.
Old 02-16-2016, 12:04 AM
Originally Posted by HighHopes View Post
Bob,
I see that restoration is mostly non-electronic. Kudos for the great job.
Thanks. Oh there was plenty of electrical work - I just glossed over it in this write up because I've done this same chassis several times now
Old 03-08-2016, 12:55 PM
oldtvsandtoy oldtvsandtoy is offline
Banned
contact cleaner
Here's the cabinet after more polishing
I lucked out with the knobs too. There are solid brass rather than plated so they can handle aggressive polishing. Admiral also used plated which are often worn down to the silvery base metal.
Do you use contact cleaner on the cabinet? If so what does that do?
Thanks to azbigsam I have the correct speaker and a whole chassis for another project.
That's better
do you use contact cleaner on the cabinet? If so what does that do?
Old 03-08-2016, 01:37 PM
I think.
Oh, it's 1.414 times the AC rating.
Old 03-08-2016, 04:00 PM
No, it's there to show a reflection in the shiny surface.
