I used no. 18 guitar string (the steel kind) to do that. It was a VERY hot day that day (upwards of 85 degrees farenheight) which helps the process greatly.
Thank you guys! Just I'll have the right time, I'll do this operation!
What do you think about the possibility of glue again the safety screen? I'd like make a work like the original system of to glue the whole screen surface, but I don't know what glue should be the best. I've seen this video where at 2.15 minutes there is the glueing of the safety screen in a Bonded B&W CRT: https://www.youtube.com/watch?v=t9hyE6jL1lg |
I am not aware of any one here that has tried to rebond. One thing I have a plan to do is to try banding a rectangle crt (for a roundie I would just leave it unbonded and unbanded). This banding will simply be a steel band that is wrapped around the crt (steel strapping) with a crimped on connector. I have no idea of the types of banding, how tight, or any other things I need to do this right, so I will be testing on a dud with lots of safety gear on.
