Old 08-19-2014, 01:46 PM
tvcollector's Avatar
Originally Posted by WISCOJIM View Post
If that's what he really meant, I saw the brightener right off in the earlier thread. I wouldn't call it hidden at all, that's the most likely resting place it would have been in when the set was in use. I certainly didn't think we as readers were obligated to point that out.
As you point out, it's really unlikely that the seller was trying to hide it.
You're not obligated to point it out.. You are correct.. But it would have been the right thing to do..
I'm a bit confused.. Some people say the Beltron is a bit hard with the rejuv, and some people say, it's not.. Same with the B&K..
Old 08-19-2014, 05:18 PM
rca2000's Avatar
rca2000 rca2000 is offline
Originally Posted by init4fun View Post
I took it to mean that the brightener was tucked behind the chassis so as to be somewhat hidden and hopefully not noticed by a potential buyer . As in , trying to hide the evidence of a weak picture tube .
If this IS the case , it's a wonder why the seller didn't just outright remove the brightener rather than tucking it partially out of sight ???
Doing THAT without admitting it to a buyer who expects a good tube--to me anyway--would be FRAUDULENT He should have ADMITTED the tube was weak and on a brightener. Not all that different than the old "sawdust in the gears" trick, IMHO.
Old 08-20-2014, 10:18 AM
init4fun's Avatar
init4fun init4fun is offline
Hi rca2000 ,
Of course it would be fraudulent to knowingly remove a booster to deceive someone into thinking a tube was in better condition than was actually known ..... Now , this is exactly why I (and I suspect Jim also) think there was no attempt at deception ; the very presence of the brightener in the set . If the seller were a crook , and knew what the brightener actually meant , wouldn't you think he would have just outright removed it rather than trying unsuccessfully to tuck it out of sight ?
Old 08-19-2014, 04:30 PM
I went over to my storage.. Attempted to to restore using the B&K, tried both the red and green guns.. It didn't want to restore as the needle didn't move much at all.. Then I attempted with the Beltron, and obviously it tries to restore all three guns while doing a rejuv.. The light indicator flashed on the blue gun side, none of the others.. And now blue tests really good, and others very poor.. I didn't try going into the more intense restore features on either of the testers..
Old 08-19-2014, 05:35 PM
rca2000's Avatar
Your tube sounds a LOT like the one in my 29JC20. The red gun is quite waek--but the other 2 test well on the 70. it will NOT help the red gun much...the cathode just will not draw enough current to restore. Boosting the fils. DOES help some, and emissions on the red get almost normal..--as does a brightener. But--those are scarce around here. I had a whole BOX Of them, including a number of roundie ones, maybe from an Estes auction or such. BUT--the geniuses who robbed my garage last year CUT OFF ALL of the wires to them..leaving JUST the bodies of them !! If I HAD to--I could "patch one in", to the old harness, I guess.
As for that B&K rejuv...I KILLED an in-line T-815 Mag. tube in 1989 I think..trying to bring it up some..it ALMOST worked...THEN..if left it MUCH worse then before !! (I was able to get a rebuilt tube for it, and it lasted well in my use till I got my CTC-169 in 1998. through a 'mix-up" that tube cost me NOTHING.) this was WAY before I had my "jewell" the CR 70. back then--they cost nearly a grand or so. I paid LESS then 100 for mine--in the mid '00s or so WITH shipping.
Old 08-20-2014, 10:48 AM
Old 08-22-2014, 03:17 PM
... Then I attempted with the Beltron, and obviously it tries to restore all three guns while doing a rejuv.. The light indicator flashed on the blue gun side, none of the others.. And now blue tests really good, and others very poor..
I have a Beltron, and its instructions tell you to select which gun to rejuv (so you don't do it to a gun that is good). The red-green-blue selector switch. So maybe you can return to the set and do the red and green guns, but don't do the blue gun.
Old 08-19-2014, 04:54 PM
Are you sure it does not have some control to rejuv the guns one by one. It would seem an odd/bad design not to allow the user to select the gun to be rejuvenated.
Old 08-19-2014, 04:56 PM
I believe it doesn't.. They don't even have power switches..
Old 08-19-2014, 05:25 PM
rca2000's Avatar
Most brighteners are NOT like that--they are just simple transformers that boost ALL 3 guns fils somewhat--to get more emission...for while. You must remember-these were sold to the PUBLIC--and therefore--could not be overly complicated.
Now--there WERE single-gun boosters out there--that would somehow increase emissioins on either ONLY one gun, or all 3 individually. These generally were NOT meant for the average consumer and sold more through parts outlets. The normally DO have control(s) on them, Chamberlin and Oneida are 2 brands I can think of.
Old 08-19-2014, 10:11 PM
reeferman's Avatar
When and who sold boosters to the general public? Through 1973 when I got out of the business, I never saw one marketed to the public.
Interesting. When were these 1,2 or 3 gun boosters introduced to the market?
Old 08-19-2014, 10:40 PM
rca2000's Avatar
I KNOW they were around in the mid-1970's, maybe before. The Oneida "nu brite" with a control for each gun was from about 1977. Older--simple all-or-none-brighteners appeared for color tubes sometime in the 1960's.
Evidently--Radio Shack even sold them a long time ago, at least for BW tubes. On ebay right now--someone is selling some brighteners, one is an Archer and one is a blue gun only tele-matic
http://www.ebay.com/itm/271574282281...84.m1423.l2649
Old 08-20-2014, 07:20 AM
sampson159's Avatar
sampson159
we had thompson electronics downtown that sold brighteners.anyone could walk in and buy.also,united tuner,sun tv,etc.lots of brighteners sold here in central ohio
Old 08-20-2014, 10:23 AM
init4fun's Avatar
And I will agree 100% with sampson159 that back in the day when tubes were regularly sold in drugstores , ALL kinds of things like brighteners and fuses and dial light bulbs could be found in the shelves alongside the tubes . Granted , I was raised in a big city , and one advantage was well stocked stores
Old 08-20-2014, 10:17 AM
i picked up on ebay 2 of these gun boosters and they dont have a transformer in them and they had them for red, green, and blue i dont think it raises any voltage except amplifys whats there already and dont seem to kill the tube for whats left in it already.
