Old 10-10-2015, 02:28 PM
Dan Starnes's Avatar
Gizmo Nut
Makes sense. I am going to try an NOS tube in the vertical output. I am skeptical about the one in it. And I will look at the yoke. See if it will move in further.
Old 10-10-2015, 03:39 PM
Gizmo Nut
The yoke did move in a bit. Good eye!!!! I pulled the chassis and am going to replace the one tube once it arrives. After that I will take prior advice and start measuring voltage.
Old 10-10-2015, 03:42 PM
Gizmo Nut
And redo the couplates as suggested.
Old 10-14-2015, 12:17 PM
Gizmo Nut
Replaced the tested weak vertical output tube with an NOS. Have owned this set for 8 or 9 years and it is performing better than ever. Cell phone pic does not do justice as to how well it is working. Still some more to do to get it where I want, but feeling lucky on the improvement on just replacing a weak tube. I feel comfortable in watching it for a half hour or so now. Next is to replace couplates.
Old 10-14-2015, 02:58 PM
Excellent! I'm glad you got the vertical working properly
