Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Transistor Portable Televisions
Old 02-06-2015, 09:52 AM
kvflyer kvflyer is offline
If I read correctly in the first post, the set was recapped? Could one of the capacitors in the horizontal oscillator be off by a factor of 10? For instance, if it called for a .001 µFD maybe a .01 µFD was installed?
Just a thought.
Old 02-06-2015, 10:41 AM
Arcanine's Avatar
Arcanine Arcanine is offline
I see you have it tuned to channel 13. Have you tried the set with a digital converter on channel 3 or 4?
I have a Blonder Tongue modulator. Channel 13 is the channel I have best clarity with in my house.
And all the capacitors where carefully selected and replaced to have nearly identical values. The only one I had issues with was the 2uF caps. I replaced those with NP 2.2uF caps.
This set had the identical symptom before I even changed out the caps. It basically changed nothing.
Old 02-06-2015, 11:48 AM
Arcanine's Avatar
I opened up my working set, and removed the sweep board for compareson. After studying both boards I found a .01 cap is missing on the top section of the board.
It's a cap I don't have so I have to make a run out to Chesters.
The missing cap is in the horizontal section.
Old 02-07-2015, 03:26 PM
Was just wondering if the modulator had something to do with scrambled image.
