Old 06-17-2015, 10:36 AM
SwizzyMan's Avatar
Restoring an admiral c322
the general conscience is there is no conscience.
Some like epoxy, some like silicone (wire safe), some like super glue (I used the flex zap in the past), some like white glue... it goes on and on and on.
Hence my recommendation to simply wrap some electrical tape around it to stablize, get the set working, then you can spend time researching what you think is the best approach. The issue I see you have is the sloppy work already done may make removal a iffy thing. And you don't want to follow up that sloppy work with more perm glue that will just make it harder to do right at some point in the future.
often times LESS is MORE in tv work. this is why untouched sets are prized over "restorations" unless the restoration is done by someone that really is good at it.
Clearly this was not the case with your CRT socket.
At some point you may have to address it (like if you had to replace the yoke), right now its a non issue to get it working, just don't do more damage to it than already done.
Yeah I'll just electrical tape it for now. Heh, maybe you could stop by and help out.
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
Old 06-17-2015, 12:54 PM
WISCOJIM WISCOJIM is offline
Consensus?
Old 06-17-2015, 01:08 PM
Originally Posted by WISCOJIM View Post
Consensus?
I never was a good speller. but yes Consensus is what I was going for.
Old 06-17-2015, 04:14 PM
MRX37 MRX37 is offline
Looking forward to seeing it running, whatever you do. Keep us posted.
Old 06-23-2015, 07:21 PM
after recapping check to see if the raster is filling out the screen. You have to be careful with all the whack formats that are out there now. You need to make sure you have a good 4:3 format. If the raster is filling out the screen, and then you get bars on the blanking bars on the top and bottom or sides, then its prob the video format. Post of some pics or better video of your progress.
Old 06-23-2015, 09:05 PM
SwizzyMan's Avatar
Went ahead and recorded a video addressing my current issue with the set. https://www.youtube.com/watch?v=SSkjb6RyOfs
Old 06-23-2015, 09:13 PM
tvcollector's Avatar
Looks like it's losing horz sync.. I would check to see what the current is at that cathode of the horz output tube.. Should be around 200ma range... Something I should have done before smoking the fly in my Magnavox set..
Old 06-23-2015, 09:41 PM
SwizzyMan's Avatar
Checked everything. All readings normal and I am pretty sure I fixed it. Now the question is how do I get the colors right? And the purity and convergence the best I can WITHOUT a pattern generator.
Old 06-23-2015, 09:51 PM
Purity you can do without a pattern generator.. Lower both green and blue drives on a station that is not coming in (Just Fuzz), and then once you have the yoke adjusted, you'll have to switch to a TV program to level all three drives.. If you can find a station that is letter box, you can go by the color of the bars on the top/bottom to level the grey scale.. I think there is a place to where you can download a DVD of the patterns... Convergence you'll need the patterns and using the cross hatch pattern is the best for that, or at least for me it is..
Old 06-23-2015, 09:54 PM
SwizzyMan's Avatar
Originally Posted by tvcollector View Post
Purity you can do without a pattern generator.. Lower both green and blue drives on a station that is not coming in (Just Fuzz), and then once you have the yoke in the best place, you'll have to switch to a TV program to level all three drives.. If you can fine a station with the letter box you can go by the color of the bars on the top/bottom.. It's harder to do that way, but can be done.. I think there is a place to where you can download a DVD of the patterns... Convergence you'll need to patterns and using the cross hatch pattern is the best for that, or at least for me it is..
So dont I do it until the screen is completely red?
Old 06-23-2015, 10:28 PM
To perform purity on a set, you'll need to start with red and also degauss the tube before you start... Pull the yoke back and adjust the purity rings until you get the red blotch in the middle of the screen then push the yoke forward again and see if red fills the screen without any fading...
Shango has videos that are helpful
https://www.youtube.com/watch?v=QNtsTKVPO7I
https://www.youtube.com/watch?v=1AWG61TAIHg
Old 06-23-2015, 10:40 PM
SwizzyMan's Avatar
Ugh, I dont have a degaussing coil.
Old 06-24-2015, 12:05 AM
Then buy or make one. http://videokarma.org/showthread.php?t=264048
Old 06-24-2015, 07:48 AM
at about 7:00 it talks about setting up purity.
Before doing anything else I recommend you look on ebay for an RCA color service manual by carl babcoke.
http://www.ebay.ca/itm/RCA-COLOR-TV-...3D311360906136
oh and start looking for a degaussing coil.
Old 06-24-2015, 07:55 AM
there are height and lin adjustments as well as a vert centering adj. All of those are used in setting up the correct sweep.
The book I mentioned covers this. There is a correct process in setting up a set, needs to be done in order. a quick summary goes like this
set height and lin using test pattern.
degauss crt
purity setup
center converge with dots from test pattern
dynamic converge with grid from test pattern
