Old 01-28-2016, 09:06 PM
Hermit418 Hermit418 is offline
Originally Posted by kydog View Post
]New to this forum but wanted to post a few pieces I found at a local thrift. Can anyone tell me what I have here?
Realistic tcr x23 with Astatic D104 mic
Realistic Trc 24b with realistic mic
A rather large gray Phantom ham/CB tube amplifier ? A/S scanner box I can't seem to rotate the images?
The amp is a Phantom 500 linear amp. They also made larger amps but from the front panel I believe it is a 500 model. Roughly expected to put out about 500 watts. Before using it have ti checked out by a competent tech.
Also since it was made for 11 meters it could be reworked to run on 10 meters and with the proper licensing you could use it without any worries. I would you not use it on CB as it is illegal and the FCC is quite fond of dishing out very serious fines including taking away all your toys if caught using one on CB. Just get a General class Ham Ticket and mod it re-work on 10 meters and avoid any hassles.
Since all of the other items except for jpeg 185 has been id'ed here goes:
That little box is a switching device/antenna switch to control an antenna called the Super Scanner (Antenna Specialists circa 1968 thru 1980s)which consisted of 3 vertical dipoles and you could switch on one to act like a sort of beam or switch on all three at once and go omni-directional. When in a single position the gain in transmit/receive was claimed to be 8.75 dB and in omni mode it was claimed to be 5.75 dB gain. Most folks ran verticals during the CB heyday and many still do. Some run beam antenna which allow you to focus more in a specific direction and basically block or reduce the unwanted signals from the other direction. Beams can be vertically, horizontally or even circular in polarization and the reason depends on what the user is trying accomplish.
The box might still be used as a switch box but the antenna with it is a fun thing to find if it still working condition.
Hope that helps.
Hermit
