Old 05-29-2016, 08:07 PM
robert1's Avatar
robert1 robert1 is offline
Originally Posted by Retro-guy View Post
Okay back to this set
It still has a problem and that is the picture is very stretched on top of the set and adjusting it doesn't cure the problem, can this be due to bad fitler caps,
i would check for resistors that have drifted out of their ratings
Old 05-29-2016, 08:34 PM
Retro-guy Retro-guy is offline
gonna look into that next
Old 05-30-2016, 11:49 AM
If the PS or vertical stage lytics are bad then getting the vertical adjusted correctly will be close to impossible.
On one of my Zenith sets I changed all but ~3 of it's original lytics (the ones I left tested fine), and a few months later one of the vertical lytics went open and the vertical shrunk. Until I found and changed that cap no combination of adjustments would yield good height, linearity, and sync simultaneously.
