Old 11-16-2004, 02:03 PM
1950s RCA color TV service hints
Doug,
I would definitely replace that electrolytic cap which was "burning hot" in your RCA color set (and every one of the other 55 caps in the chassis, especially in a set this old--RCA sets with single-digit CTC numbers are generally from the '50s), but not before finding out what was overloading it so badly. Any component in a TV or radio that gets so hot it will burn your fingers (or smokes) has been severely overloaded by something, usually a short in the power supply. I'd check to see if the rectifier tube(s), if used, are shorted, for starters (in a set of '50s vintage, you will probably find at least one and likely two 5U4s or 5Y3s in there; I'd test them just as a matter of routine--one or both might be weak). However, if the set basically works (as your pics of the screen are showing--that screen shot from CNN looks great), I would just test the tubes for cathode emission, and even if they test good, I'd replace them on general principles. Even if they work halfway decently now, you can be almost certain that tubes five decades or more old are on their last legs (this long a life span for a single set of vacuum tubes in a television set is darned nearly incredible, unless the rectifiers have been replaced at least once since the set was new), and probably will fail before too much time goes by.
If you're planning to restore this set, it would be a good idea to replace the rectifiers anyway, along with any other tubes you find in doubtful condition. I would replace them all if you are looking to restore this TV to its orginal condition (or close to it).
Whatever you do, don't run that chassis any length of time if you have a problem such as a red (white?)-hot electrolytic, as it could damage the power transformer if the supply is not fused.
I agree as well that you should not fiddle with the CRT if it still makes a good, bright picture. Using a brightener on a good tube can and often does shorten the life of the CRT, by virtue of running the heaters at voltages higher than that for which they were designed. Brighteners are OK for use with weak CRTs, but I wouldn't use one on a good tube. I read somewhere, however, that if you raise the voltage on a weak CRT and the filaments do burn out, they were probably, even likely so weak they would have opened soon anyway, even at normal voltage. The heaters in good CRTs are designed to handle voltages a certain percentage over their usual ratings (I don't recall the exact number offhand), but I wouldn't trust an older tube with filament voltage that much above normal.
I'd say use a brightener if you must, but if the tube works well without it, don't. 21CYP22s or other roundie color CRTs are probably difficult to find these days (almost impossible to find in NIB condition, though you might be able to lay hands on a NOS tube for a reasonable price, or find a good tube in a junked set), so I would say try to get as much life out of the original in your set as you possibly can.
Good luck. Glad to see a set that old making such a good picture after all these years. New "RCA" branded sets made by Thomson won't come close to lasting that long, even though the company has (supposedly) licked the onboard tuner problems they were having with sets of 1990s vintage.
The CRTs in these new sets are getting better as far as quality goes as well, as the picture quality and reliability of these tubes seems to be better (much better) than it used to be. I have an RCA CTC185 (19-inch XL100) in my apartment; I purchased the set new when I moved here five years ago and haven't had five minutes' worth of trouble with it, except for one small problem with the RF port on the tuner PCB snapping off a few months after I bought the set. The tech who repaired the problem also resoldered all the ground points around the onboard tuner. Must have done a good job, as the set has been working extremely well, good picture on cable and all, and no other chassis problems whatsoever, since the repair was made almost three (or maybe four) years ago. (I also have a nearly-10-year-old 19" Zenith Sentry 2 in my bedroom that has never been serviced and still works almost as well as when it was new, but that's another story, one I'm sure I've told in another thread some months ago.)
I don't expect my RCA set (or my Sentry 2) to last anywhere near 50 years, but at this point I am hoping both sets give me good service for some years to come (even when TV goes all-digital in 2006, I hope to be using the RCA set on cable with a converter, with the Zenith in standby service). As well as both sets are working now, another few trouble-free years wouldn't surprise me; someone here said that, even though some early Thomson CRTs are bad news, if you get a good one (as I obviously must have in my RCA set and also the Zenith), it will last for years.
Kind regards,
