Old 11-30-2015, 07:57 PM
slatton86 slatton86 is offline
DishDude nailed the Pay TV knob, I read it in the manual long ago.
Man those crazy RF chains full of splitters and switches we used to wrig up could be nuts.
I used a VCR similar to this when I was a kid and with it I discovered that (at least for my CATV near Memphis TN)
I could run my cable box to the VCR with RF
and the VCR to another via composite video(probably could have skipped this with a better tv),
tune the box to HBO,
cut the composite video cable,
switch the polarity,
and I had HBO!
we had only 3 premium channels HBO, Cinemax and Disney and we didn't pay for any. The only reason for the box was my 70's model Quasar.
Old 11-30-2015, 09:49 PM
Dude111 Dude111 is offline
Analogue is Awesome
I remember on my black and white TV I had a "FINE TUNE" slider and I could "fine tune" a scrambled picure in enough to watch it
Ah man!!
Old 02-11-2019, 12:48 PM
svhs's Avatar
svhs svhs is offline
DIGITRON
Thumbs up
Ah yes it comes back now. It has that AUX jack in the back .... never saw a descrambler for that. Another obsolete technology.
It's DATA jack fit to that AUX jack to Scientific Atlanta Digital cable Set top box Explorer 2100 tv decoder
https://www.ebay.com/itm/352588178603
fun
https://youtu.be/tnY7UVyaFiQ?t=37
humm
l don't find nothing here http://theoldcatvequipmentmuseum.org/170/173/1731/
hi
i am
Visual
Old 02-12-2019, 02:08 PM
svhs's Avatar
DIGITRON
Lightbulb
Equivalent to the Panasonic PV-1730. I almost bought one back in the day, but it was ahead of the MTS stereo standard so it lacks a stereo TV tuner. This has direct drive reel motors which is why it lacks most of the usual belts & idlers.
That Pay TV switch has to do with the old subscription boxes they had back in the early-mid-80s like On TV. You would set it up to the channel the descrambler box put out so the VCR would switch to it. Something like that...
EXACTLY
Originally Posted by dishdude View Post
The PAY TV switch worked with an adapter that plugged into the AUX port. If you needed a cable box to descramble HBO, it allowed you to split your cable line to the VCR and cable box, then run the output of the cable box to the adapter. This allowed you to tune a scrambled channel on the VCR tuner so you could set timers on multiple channels.
The AUX port Is For Sound multiplex adapter
HERE EXAMPLE For National Panasonic TU-802(M) TV Sound Multiplex Adaptor
Just LOOK THIS DIN CONNECTOR - It-Fits EXACTLY to the DIN aux female port on EVERY MTS READY TV/VCR,that not have bluit mts
Hitachi VTMTS2 MTS stereo Adaptor for older model Hitachi TV"s and VCR"s with stereo Adaptor jacks. Some VCR"s that are compatible are VT-65A--VT76AY--VT-89A--VT-86A--and VT-87A. Complete with Adaptor type F cable DIN cable and stereo RCA cable.
HERE another Panasonic Quasar Portable VHS Video Cassette Recorder and Quasar tuner with DIN aux female port ,BUT without PAY TV switch
hi
i am
Visual
Old 02-17-2019, 10:28 AM
svhs's Avatar
DIGITRON
Lightbulb
CABLE ADAPTER JACK Connection for external antenna switcherCONTROL CONNECTOR
This 5 Pin DIN switches the coax input of the 1 X 4 Switch to one of the 4 coax outputs. The 1 X 4 Antenna Switch Control Connector may be connected to the 3 X 1 Controller / Switch 1 X4 Select 5 pin DIN output. Below is a picture that defines the function of the pins on the 5 PIN DIN.https://www.w2ihy.com/1-x-4-coax-switch.html
The 1 X 4 Coax Switch is designed to be used with the W2IHY 3 X 1 Controller. When the 1 X 4 Coax Switch is attached to the W2IHY 3 X 1 Controller the connectivity of the controller is significantly expanded. The 1 X 4 Coax Switch is built with a Rugged steel case and when used with the W2IHY 3 X 1 Controller
connects any one of 3 radios to any one of 3 amplifiers and/or up to 4 antennas
Capable of easily handling 10,000 watts PEP of RF.
Wall or desk mountable
Dimensions 6 ˝ I” W x 1-5/8” H x 2 5/8” deep
hi
i am
Visual
Old 05-21-2019, 12:09 AM
waltchan waltchan is offline
This same mechanism chassis was also found in Panasonic AG-1950 industrial VCR.
Old 01-07-2021, 11:30 AM
svhs's Avatar
DIGITRON
Cool Rca cad030 cable adapter
FINALLY
hi
i am
Visual
Last edited by svhs; 01-17-2021 at 07:05 PM. Reason: ladies and gentleman we have hit the jackpot.
Old 01-07-2021, 01:57 PM
svhs's Avatar
DIGITRON
Lightbulb National/VZ-C80 + WV EC310E+RCA CAD030
https://www.canuckaudiomart.com/deta...mages/2774154/Yamaha RS-KW5 Wireless Remote & Receiverhttps://reverb.com/item/15506824-jvc...d-stereo-tunerVICTOR T-X900The biggest feature of the TX900 is that it actively introduces computer control and sets the optimum reception mode according to the reception status.
It was that we had completed and installed a system that could automatically set the motion and even control the antenna. This automatic control
Memory set function such as sensitivity, IF band, stereo QSC (Quiting Slope Control) for each receiving station
It was equipped with two antennas, A and B, and a memory for the direction. In particular, in addition to the automatic antenna switching function of the two systems,
When the specified antenna rotator (Emoto Antenna Co., Ltd. Emotator 202VF) is connected, the tuner ante
Remote control is possible with the Na Adjust key, and you can adjust and make notes by looking at the accurate electric field strength display of the tuner.
By releasing, the antenna direction is automatically directed to the direction once set by the receiving station.
hi
i am
Visual
Last edited by svhs; 02-20-2021 at 11:47 PM. Reason: https://reverb.com/item/15506824-jvc-fx-33-fm-am-computer-controlled-stereo-tuner
Old 02-20-2021, 11:47 PM
svhs's Avatar
DIGITRON
Cool
https://www.head-fi.org/threads/hear...anyone.172576/Channel Plus DA-550BID https://www.qsl.net/yo3dan/fc20
hi
i am
Visual
Last edited by svhs; 02-25-2021 at 11:07 AM. Reason: JVC Receiver RX-8VYaesu FC-20 automatic antenna tuner
