Old 12-19-2015, 01:52 PM
He probably mixes the two S-video lines and has a switch in the color line to disconnect it.
That's essentially it, though here I created a low pass luma filter, a bandpass chroma filter and merged these to create a composite video signal that would look good on older color TV sets (the one that use a notch filter). I switch that and an unfiltered luma only signal.
Old 12-19-2015, 02:38 PM
Kevin Kuehn's Avatar
Workin' Late Again
Thanks for sharing this. And what type of rf modulator are you using that runs on 5 volts?
Old 12-19-2015, 03:31 PM
I dunno, so I asked Google:
http://www.talonix.com/shop/item.aspx?itemid=10044
2 bucks.
USN RET 22YRS (Avionics/Cal)
Old 12-19-2015, 05:16 PM
Workin' Late Again
Hey, those are cute.
Old 12-19-2015, 05:47 PM
Colly0410 Colly0410 is offline
My DVD recorder/player RF output can be tuned to any UHF channel from 21 to 68 for older TV's. No English TV's made since 1969/70 were fitted with VHF tuners as VHF TV was phased out & we became a UHF only Country. Early video recorders were factory preset to channel 36 RF output as that has never been used for TV broadcasting, but you could adjust the output between channels 30 & 40 with a screwdriver, later ones could tune 21 to 68. Channels 35,36,37 & 38 were not used until the channel 5 network started broadcasting on ch 37 in 1997, then on ch 35 in 1998, this could cause adjacent channel interference & ch 5 had to send re-tuning engineers to affected areas FREE of charge to viewers. It cost them millions of pounds. Of course it's all digital now so problem no longer exists..
Old 12-19-2015, 06:30 PM
Naw, these are cute - and small - looks to be matchbox sized, and also 2 bux.
http://www.talonix.com/shop/item.aspx?itemid=10045
