Old 11-24-2015, 02:29 PM
Kevin Kuehn's Avatar
Workin' Late Again
Originally Posted by Radiotronman View Post
Ok, I'll try that, but how can you tell which are terminals 5-6. They're not numbered.
Looks like terminals 5-6 are in parallel with R89(22k).
Old 11-24-2015, 02:45 PM
No, that's plenty close enough.
Old 11-24-2015, 03:25 PM
Radiotronman's Avatar
Ok, there was another cap stuffed behind a terminal board I didn't see connected to the horizontal oscillator transformer (.01). I replaced it and the horizontal us much better, but still unstable. The vertical is unstable as well. At least I have done firm of a picture. Now to get the sync stable...
Old 11-24-2015, 04:01 PM
I can get the horizontal to hold for only seconds at a time.
Old 11-24-2015, 04:10 PM
Workin' Late Again
Did you try what bandersen suggested?
One side of the coil adjusts the shape, the other side the free running frequency, That's usually the end that is accessable from outside the chassis. Set the horizontal hold control in the center and adjust that coil until you get a lock.
Old 11-24-2015, 05:05 PM
If tweaking the hor. oscillator coil doesn't help and vertical is touchy too, possibly an issue in the sync circuit.
Old 11-24-2015, 05:16 PM
The 150K is pretty close and the 68k reads 61.5k. Would that being less cause it?
Easy enuff to find out. Bump the value up by sticking a resistor in series with it. Try say, a 8.2K and see if it improves the lock-in range, or makes it worse.
(Of course this isn't gonna address the sync issue.)
Old 11-24-2015, 05:23 PM
I adjusted the end in top of chassis, but it didn't really do much. The one underneath has s partially broken s www head. But I didn't out the horizontal hold in center when adjusting the top one. I can try that.
Old 11-24-2015, 06:11 PM
Originally Posted by earlyfilm View Post
Crosley TVs were never big sellers, although their radios were very common.
Reminds of a page that I ran across the other day. Scroll down and look at the TV pictured for 1954:
http://www.crosleyradio.com/about
And I quote: "The first portable TV set was pioneered under the Crosley brand name, and becomes the best selling set in the industry."
What a hoot. TVs of that size (and smaller) were sold years earlier by other companies. And I seriously doubt that TV was really the best selling set in the industry, in 1954 or any other year. Never laid eyes on one, myself.
In fairness, that website has little connection with the original Crosley company. It's the headquarters for selling new repro sets under that name.
Phil's Old Radios
Old 11-24-2015, 06:40 PM
Ok, I tried doing what Banderson suggested and I can get a picture, but it will not hold. Constantly having to readjust to keep it close. Should I look in the sync section?
Old 11-24-2015, 06:54 PM
EdKozk2 EdKozk2 is offline
Tinker
I once had a RCA KCS 68 chassis with close to the same horizontal circuit. The set had the same symptoms as your Crosley. The trouble was bad mica and paper caps in the sync circuit.
Ed
Old 11-24-2015, 07:35 PM
Workin' Late Again
Have you tried adjusting the Horizontal Lock trimmer? Sams shows it as B2 on the back right side of the chassis? That trimmer cap sets the sync input level to the AFC portion of the horizontal oscillator. Otherwise I guess look over the sync circuit. An oscilloscope could be real handy right about now.
Old 11-24-2015, 07:45 PM
Phil's Old Radios
That set came out in the late 40's like the the rest of the E'stat sets.
The Motorola was the best seller of all of them.
Old 11-24-2015, 08:07 PM
When the adjustment screw was damaged, I would solder a 6/32 nut to the screw and use a nutdriver to do the adjusting.
The Riders for the slightly newer 12" set has a notation on the schematic, for improving the horiz hold range. Replace the 150k resistor, r87 on the Sams to a 100k and see what happens. As others have noted, the sync circuit seems to need further trouble shooting.
Old 11-24-2015, 08:09 PM
Could you post the schematic covering the video detector and video amp chain?
I'm wondering if there's a chance the vid.detector diode* could be installed backward. There's been a couple of such cases on this forum, and it produces a display very much like what's seen in the screen shot you posted.
*That's assuming it uses a SS diode (1N34 etc.) and not a tube diode (6AL5 etc.)
