Old 12-11-2015, 07:44 PM
Olorin67 Olorin67 is offline
making the spring stronger will lessen the tracking force, the spring counteracts the weight of the tonearm. that cartridge will need at least 6-7 grams , lighter than that will cause mistracking, sounds bad and hard on the records. NOS cartridges are highly likely to be bad, unless the seller tests and guarantees them. I know someone who bought a whole case of NOS 89Ts, every single one was bad...
Old 12-11-2015, 09:07 PM
Banned
Often if one end of the spring can be removed one can edit down the spring by chopping a few coils off, bending the end to hook on the old connection point, testing tracking force and repeating if necessary.
By the looks of that clip that's attaching the spring though it looks like it wasn't meant to be adjusted, and I've seen some of those types of clips before, they're not meant to be removed and reintalled again because when you remove it, you have to replace it with a new one or just not remove the original, which is why I said it probably wasn't meant to be removed or readjusted.
Old 12-11-2015, 11:49 PM
The top spring post looks the way you describe (I would not mess with that one), but the bottom looks like the spring is probably merely hooked on it....At least to me.
Old 12-18-2015, 09:26 PM
kb12 kb12 is offline
I purchased a new cartridge and shortened the spring a bit and now it seems to be working much better! Again, thanks for the help.
I have another problem though... I have a flip cartridge (81T) and both sides say "LP". Both side say "LP" on my 89TX as well. Both needles look the same to me. The cartridges only mount one way. Can anyone confirm which side is for 78s and which is for LPs?
Old 12-19-2015, 12:12 AM
Neither is specifically for 78's....There were ones with one side of the turnover as 78 and others with both as 33....There were library of congress talking book (for the blind) phonos that only played 33, 16, and 7(or 8) RPM microgroove records that were better served with a second stylus for when the other 33 one wore out, than a 78 that would damage an LP....It is fairly safe to play a 78 with a LP type styli...It will be smaller than the groove and thus add more noise scraping the bottom of the groove and bouncing within it.
Old 12-19-2015, 09:52 AM
When looking at the unit from the front, the LP tip is available when the lever is on the left side. The 78 tip is available when the lever is on the right side. The best way to tell if you truly have either dual LP tips or LP/78 tips is to play a portion of a 78 with the LP tip and then play the same record with the other tip. If the other tip sounds less noisy, you have an LP/78 cartridge.
